[postgis-users] GNU Autoconf / Automake Expert Needed
Bernhard Reiter bernhard at intevation.de
Thu Aug 29 10:06:51 PDT 2002
Just a note:
If you are not settling on the autoconf configure make process,
you might want to consider Scons as a make replacement.
	http://www.scons.org/
On Thu, Aug 29, 2002 at 09:22:33AM -0700, Paul Ramsey wrote:
> create an appropriate GNU build control system for it,
> preferably using the autoconf, automake suite of tools to make a
> traditional GNU installation.
Name: not available
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20020829/d7946a24/attachment.pgp>
