[postgis-users] libproj.so.0: cannot open shared object file
Paul Ramsey
pramsey at refractions.net
Thu Dec 5 11:50:43 PST 2002
Is /usr/local/lib in your /etc/ld.so.conf file? If not, add it and then
run 'ldconfig'
P
EOsorio at sisdef.cl wrote:
> Hello, I have installed postgres 7.2.1 and I try to install postgis 0.7.2
> , and when I run the next sentence, I have the next error, I try to use
> PROJ4.x,
> Apparently I have the same problem with postgres 7.3 and I try to install
> postgis 0.7.3.
> Please help me.
> [postgres at linux postgis-0.7.2]$ psql -f postgis.sql cartografia
> BEGIN
> message
> plpgsql is installed
> (1 row)
> CREATE
> psql:postgis.sql:29: NOTICE: CREATE TABLE / PRIMARY KEY will create
> implicit index 'spatial_ref_sys_pkey' for table 'spatial_ref_sys'
> CREATE
> psql:postgis.sql:42: NOTICE: CREATE TABLE / PRIMARY KEY will create
> implicit index 'gc_pk' for table 'geometry_columns'
> CREATE
> CREATE
> CREATE
> CREATE
> CREATE
> psql:postgis.sql:218: NOTICE: ProcedureCreate: type box3d is not yet
> defined
> psql:postgis.sql:218: ERROR: Load of file
> /usr/local/pgsql/lib/contrib/libpostgis.so.0.7 failed: libproj.so.0: cannot
> open shared object file : No such file or directory
> psql:postgis.sql:223: NOTICE: current transaction is aborted, queries
> ignored until end of transaction block
> *ABORT STATE*
> psql:postgis.sql:228: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:233: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:240: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:247: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:252: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:260: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:268: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:273: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:278: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:287: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:297: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:302: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:307: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:312: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:317: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:322: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:328: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:333: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:338: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:343: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:351: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:356: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:366: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:381: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:388: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:393: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:398: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:404: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:412: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:417: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:422: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:434: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:439: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:444: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:449: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:454: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:459: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:464: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:469: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:474: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:479: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:484: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:489: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:494: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:499: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:504: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:509: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:514: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:520: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:525: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:530: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:535: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:540: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:546: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:551: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:556: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:561: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:566: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:571: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:578: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:583: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:588: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:595: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:600: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:605: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:610: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:615: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:620: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:625: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:630: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:635: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:640: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:645: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:653: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:658: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:663: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:668: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:673: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:678: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:683: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:690: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:696: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:701: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:707: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:714: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:717: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:720: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:723: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:726: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:729: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:732: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:735: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:740: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:743: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:746: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:751: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:754: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:759: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:763: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:764: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> COMMIT
> BEGIN
> psql:postgis.sql:772: ERROR: argument type geometry does not exist
> psql:postgis.sql:775: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:784: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:787: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:790: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:793: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:798: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:800: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:802: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:810: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:816: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:822: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:828: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:834: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:840: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:848: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:855: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:861: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:867: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:873: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:886: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:894: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:903: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:912: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:921: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:930: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:939: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:948: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:957: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:966: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:968: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:978: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:986: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:994: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:1002: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:1010: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:1018: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:1026: NOTICE: current transaction is aborted, queries
> *ABORT STATE*
> COMMIT
> Eliecer Osorio Verdugo
> Ingeniero de I&D
> SISDEF Ltda.
> eosorio at sisdef.cl
> postgis-users mailing list
__
| Paul Ramsey
| Refractions Research
| Email: pramsey at refractions.net
| Phone: (250) 885-0632
\_
