[postgis-users] PostgreSQL 7.3 Support
carl anderson
candrsn at mindspring.com
Thu Dec 5 17:58:04 PST 2002
under PostgreSQL 7.3
createdb -T template0 test;
psql test < postgis.sql
psql < spatial_ref_sys.sql
succeeds
after that
psql test < postgis_undef.sql fails
first I edited postgis_undef.sql to have
drop AGGREGATE extent (geometry);
drop AGGREGATE collect (geometry);
but then
DROP AGGREGATE
DROP AGGREGATE
ERROR: cache lookup of opclass 34433 failed
of course the oid of the opclass is specific to my installation.
It appears that PostgreSQL 7.3 uses stronger operator/function/operator
class
type checking;
I have previously had success with an undef using
drop type geometry cascade;
which won't work with older PostgreSQL versions
I checked the Mapserver CVS and did not find any change to mappostgis.c
there.
Will anyone there submit a patch so that testing with mapserver can be
made?
On 2002.12.05 16:56 Paul Ramsey wrote:
> PostGIS'ers.
> The CVS version now contains beta quality support for PgSQL 7.3. This
> has not been particularly tested at all (loaded one Shape file,
> checked indexes, added some typecasting support) so your milage may
> vary. Any bugs report back to the list please.
> Paul
> __
> | Paul Ramsey
> | Refractions Research
> | Email: pramsey at refractions.net
> | Phone: (250) 885-0632
> \_
> postgis-users mailing list
