[postgis-users] alpha GT2 Web Map Server with PostGIS support
cholmes at limegroup.com
Fri Dec 13 09:11:16 PST 2002
Apologies if this gets posted twice, I'm having trouble posting to lists
for some reason:
Hey, I work on the PostgisDataSource module for geotools2. Sorry for
taking so long to get back on this issue. No, a gid field is not a
requirement of all spatial tables. We made that a temporary assumption
to get things working, using the gid field as the feature ID. I've
fixed the code, now the datasource uses the first column as the Feature
ID, which I think is a valid assumption, as the SFS for SQL spec, in
section 3.2.4.2 has the general format for the creation of a feature
table, and the first column is <FID name> <FID type>. So now as long as
the first column of your table holds the feature ID things will work.
Let me know if that is not a valid assumption, and I'll figure out
another way to do things. James has made a new release of the wms, that
incorporates my fixes as well as some new caching code that speeds
things up. It's available at:
http://sourceforge.net/project/showfiles.php?group_id=4091&release_id=127682,
the file is gt2wms-alpha-2.zip. And thank you so much for testing and
input. Let us know about any other bugs that hold you up.
Chris
On Friday 06 December 2002 12:47 am, Rueben Schulz wrote:
> Hello,
> This is an update of my progress with gt2wms testing with postgis data.
> I now have lots of logging output, and the source code to help me track
> down problems.
> None of my data was displaying initially, because of a database
> permission problem. I have learned that the postGIS connection uses the
> geometry_columns table to find the geometry column to use for a spatial
> table. I did not have read permission on this. With this fixed I now
> have 2 of my 8 datasets displaying.
> The rest of my data is not displaying because of a
> ArrayIndexOutOfBoundsException from the postGIS connection. It appears
> that the PostgisDataSource connection assumes that the spatial table has
> a gid field.
> My question to the postGIS community then is: is a gid field a
> requirement of all spatial tables? I have not come across this in any
> documentation.
> I also have another problem with a multipolygon dataset, but it will
> have to wait until the above is sorted out.
> Rueben
