[postgis-users] alpha GT2 Web Map Server with PostGIS support
Paul Ramsey
pramsey at refractions.net
Fri Dec 13 09:44:41 PST 2002
A counter point to this one is that oids are *not* indexed by default.
The "best" first choice for a uid would be the column which is flagged
as the "primary key" as that column is both guaranteed to be unique and
indexed. Failing that, the oid would be a reasonable backup, since it is
at least guaranteed to be unique.
P.
chodgson at refractions.net wrote:
> You might be better to use the OID value for the feature identifier. After all,
> it is entirely possible to have a table with only a geometry column. The OID
> value is what the mapserver connector uses by default (but you can specify
> another column if you want). The OID is an "invisible" column that postgres
> adds to all tables, if you didn't know - it's the "object identifier" and is at
> least unique for all of the rows in a given table.
> I would highly recommend making this a configurable option, as your identifying
> column should probably have an index, as it is silly to have to index another
> column when you already have a perfectly good, indexed, unique value.
> Chris Hodgson
__
| Paul Ramsey
| Refractions Research
| Email: pramsey at refractions.net
| Phone: (250) 885-0632
\_
