[postgis-users] Selecting geocoded postal codes within a given distance ( miles for example )
Hugh W. O'Brien
hugho at intelis.com
Tue Dec 17 07:08:06 PST 2002
Vinko,
Do you remember the subject line of that thread?
I am going thru the archives now but I just joined the list yesterday so
I am not familiar with that thread.
-- Hugh W. O'Brien
Vinko Vrsalovic wrote:
>On Mon, Dec 16, 2002 at 02:06:32PM -0600, Hugh W. O'Brien wrote:
>>I probably should have posted that I am a noob to not only using PostGIS
>>but also using a spatial engine in general. So I am not familiar with
>>the terms UTM, state place. etc... So, how would one go about
>>projecting their longitude/latitude data into UTM for example. Would
>To project the data you have the transform() PostGIS function.
>>doing so convert my degrees long/lat to actual distance units such that
>>the standard bounding box example in the FAQ would be applicable?
>Yes.
>Remember that your data must have SRID's set to use the transform
>function. More info in the archives (the topic was discussed not long
>ago) and in the docs.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20021217/738d6775/attachment.html>
