[postgis-users] PostgreSQL/PostGIS as a bundled database
Frank Warmerdam
warmerdam at pobox.com
Sat Dec 28 09:36:02 PST 2002
Folks,
A client of mine is working on greater integration of their product with
spatially enabled databases for multiuser shared work environments (ie.
Oracle Spatial, SDE). However, having made their applications more friendly
to the multi-user database backed world the question arises whether they can
offer a light version of this for customers without an existing spatial
database installation.
Not surprisingly PostgreSQL/PostGIS comes up as an option. So my question
is what issues might be encountered trying to bundle PostGIS with an
application. I imagining it being installed and activivated as an optional
step in an InstallShield style install on Windows. Some sort of simple
control panel would likely be needed from within the application to administer
the database but it would desirable for it to be kept simple. The user should
be able to install the database on one machine and reach it from others.
What issues/concerns would people have about this? Some things that come
to mind for me are:
o Currently on Windows a Postgres installation has to be built in the Cygwin
environment, right? How much of that is required at run-time? I am hoping
all we would need to include out of Cygwin in the install is one or two
runtime DLLs. Are there required components of Postgres that would depend
on Cygwin shell scripts or external commands?
o To allow multiple machines on the LAN to access it the db instance would
need to be started in the mode where you can connect to it by internet
socket. In this case it would be important to install with user supplied
passwords, right?
o I am assuming that the client application would use the Win32 builds of
libpq and so would have no direct dependency on Cygwin. Anyone using this
method now? (I would really like to get this working in OGR but haven't
had the time to try it).
o How big (roughly) is a Postgres install with a database initialized but
no spatial data loaded? An Oracle 8.1.7 installation on Windows seems to
be on the order of 1GB and apparently an Oracle 9 base install is
substantially larger. I am hoping the Postgres installed with an empty
db initialized would be less than 100MB.
o How easy is it to ensure that postgres is started at boot up? Can it be
made an NT service? Is this the best approach? On unix I would ensure
that "pg_ctl start -o -i " was called from a boot script. What is the
equivelent to that on NT?
o Assuming we want to keep things simple for a user what are the minimum
database administration requirements that would be need to be exposed?
I can think of:
o Initial installation. The user might be given an option to place
the database instance somewhere other than within the installed
software tree.
o An option to start/stop/restart the database (ie. pg_ctl) and
control whether it is remotely accessable or not.
o An option to backup and restore the database.
o An option to create/delete users and set/reset their passwords.
I am assuming that creating layers, altering field definitions and
so forth would be done through the normal GUI interface for the
application rather than in a Postgres specific manner.
o What does a client install need? Just the primary application and
libpq.dll, right? The client install should only need to know the
machine name to connect to, right? Is there a default port for postgres?
would there be a reason to change it?
o What issues of conflicts with other software might we encounter? Should
we run postgres on a different port to ensure we don't conflict with any
other postgres instance that might exist on the clients systems? Are
there issues of picking up the wrong cygwin DLLs at runtime if the user
has another cygwin version installed?
o What would be necessary if we also wanted the database to be ODBC
accessable for access from other windows applications? Are there good
ODBC drivers for postgres on windows? Are there other complicating
issues to using them?
I think the open source, and free nature of PostgreSQL/PostGIS could make
it an attractive option as a bundled free spatial database for a variety of
GIS software packages. Furthermore I think it's use in this configuration
could result in commercial support for further development of PostGIS.
PS. I am working on Oracle Spatial support for OGR right now. I haven't
reviewed the Oracle 9 Spatial docs yet, but in Oracle 8 there seems to
be very little OGC SFSQL support. There is no apparent way to get
geometries in WKT or WKB formats for instance. However, the coordinate
systems are in WKT format. All in all I am disappointed so far with
the OGC standards compliance in Oracle Spatial.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
