[postgis] Problem with GeometryFromText function of chapter 3 Postgis
Silvio
torodedutoesdraiato at yahoo.it
Fri Jan 4 03:49:01 PST 2002
Hi all,
I have follow example of PostGis manual in the chapter 3 point 2:
2. How do I insert a GIS object into the database?
First, you need to create a table with a column of type "geometry" to hold your GIS data. Connect to your database with "psql" and try the following SQL:
CREATE TABLE gtest ( ID int4, NAME varchar(20) );
SELECT AddGeometryColumn('dbname','gtest','geom',-1,'LINESTRING',2);
If the table creation fails, you probably have not loaded the PostGIS functions and objects into this database. See the installation instructions.
Then, you can insert a geometry into the table using a SQL insert statement. The GIS object itself is formatted using the OpenGIS Consortium "well-known text" format:
INSERT INTO gtest (ID, NAME, GEOM)
VALUES (1, 'First Geometry', GeometryFromText('LINESTRING(2 3,4 5,6 5,7 8)', -1));
but when I do this I will have:
mydb=# INSERT INTO gtest (ID,NAME,GEOM) VALUES (1,'First Geometry',GeometryFrom
Test('LINESTRING(2 3,4 5,6 5,7 8)', -1));
ERROR: Function 'geometryfromtest(unknown, int4)' does not exist
Unable to identify a function that satisfies the given argument types
You may need to add explicit typecasts
What's the problem for this error?
Thanks
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20020104/cc8ccf07/attachment.html>
