[postgis] Install test failure
colmpdx
plancashire at columbia.com
Mon Jan 7 11:54:15 PST 2002
Postgres 7.1.3
Postgis 0.6.2
When running
psql -f /software/src/postgresql-7.1.3/contrib/postgis-
0.6.2/postgis.sql -d db
Got the following NOTICES:
psql:/software/src/postgresql-7.1.3/contrib/postgis-
0.6.2/postgis.sql:34: NOTICE: CREATE TABLE/PRIMARY KEY will create
implicit index 'spatial_ref_sys_pkey' for table 'spatial_ref_sys'
0.6.2/postgis.sql:47: NOTICE: CREATE TABLE/PRIMARY KEY will create
implicit index 'gc_pk' for table 'geometry_columns'
0.6.2/postgis.sql:213: NOTICE: ProcedureCreate: type 'box3d' is not
yet defined
0.6.2/postgis.sql:223: NOTICE: ProcedureCreate: type 'spheroid' is
not yet defined
0.6.2/postgis.sql:247: NOTICE: ProcedureCreate: type 'wkb' is not
yet defined
0.6.2/postgis.sql:265: NOTICE: ProcedureCreate: type 'chip' is not
yet defined
0.6.2/postgis.sql:286: NOTICE: ProcedureCreate: type 'geometry' is
not yet defined
0.6.2/postgis.sql:323: NOTICE: ProcedureCreate: return
type 'geometry' is only a shell
Then in trying out the USAGE section of the README.postgis file
I created a database called "db".
Edited the SQL to remove tabs etc. Espically the
INSERT INTO SPATIAL_REF_SYS ...
Everything works up to ...
INSERT INTO geotest (id, name, geopoint) VALUES (1, 'Olympia',
GeometryFromText('POINT(-122.90,46.97)',1));
Gives me the error message ..
ERROR: couldnt parse object in GEOMETRY
Did I miss something ?
Thanks
-pete
------------------------ Yahoo! Groups Sponsor ---------------------~-->
Tiny Wireless Camera under $80!
Order Now! FREE VCR Commander!
Click Here - Only 1 Day Left!
http://us.click.yahoo.com/WoOlbB/7.PDAA/ySSFAA/PhFolB/TM
To unsubscribe from this group, send an email to:
postgis-unsubscribe at yahoogroups.com
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
