[postgis] ClassCastException with PostGis Example
Silvio
torodedutoesdraiato at yahoo.it
Tue Jan 8 07:47:24 PST 2002
I have just installed PostGis with PostGreSql but the PostGis Example
doesn't work.
This is the example (http://postgis.refractions.net/docs/x441.html)
import java.sql.*;
import java.util.*;
import java.lang.*;
import org.postgis.*;
public class JavaGIS {
public static void main(String[] args)
java.sql.Connection conn;
try
* Load the JDBC driver and establish a connection.
Class.forName("org.postgresql.Driver");
String url = "jdbc:postgresql://localhost:5432/database";
conn = DriverManager.getConnection(url, "postgres", "");
* Add the geometry types to the connection. Note that you
* must cast the connection to the pgsql-specific connection *
implementation before calling the addDataType() method.
((org.postgresql.Connection)conn).addDataType("geometry","org.postgis.PGgeom
etry");
((org.postgresql.Connection)conn).addDataType("box3d","org.postgis.PGbox3d")
* Create a statement and execute a select query.
Statement s = conn.createStatement();
ResultSet r = s.executeQuery("select AsText(geom) as geom,id from
geomtable");
while( r.next() )
* Retrieve the geometry as an object then cast it to the geometry
type.
* Print things out.
PGgeometry geom = (PGgeometry)r.getObject(1);
********************CAST ERROR*****************
int id = r.getInt(2);
System.out.println("Row " + id + ":");
System.out.println(geom.toString());
s.close();
conn.close();
catch( Exception e )
e.printStackTrace();
The compiling phase is ok
After, when I try to run the class I get the following error:
java.lang.ClassCastException: java.lang.String
at PostGis.main(PostGis.java:42)
(the error is referred to the line 42 where I have written "CAST ERROR")
I hope that somebody can help me!!
Thanks in advance.
Silvio B.
------------------------ Yahoo! Groups Sponsor ---------------------~-->
Tiny Wireless Camera under $80!
Order Now! FREE VCR Commander!
Click Here - Only 1 Day Left!
http://us.click.yahoo.com/WoOlbB/7.PDAA/ySSFAA/PhFolB/TM
To unsubscribe from this group, send an email to:
postgis-unsubscribe at yahoogroups.com
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
