[postgis] GML generation scripts and question: attachments
jeff lounsbury
jeffloun at refractions.net
Wed Jan 9 12:34:09 PST 2002
> Is this a valid assumption--or is the order of the rings arbitrary? (If the
> latter, a test would be necessary to determine order.)
This is correct, both PostGIS and the WKT spec require the first ring in a
polygon to be the outer ring.
-Jeff
To unsubscribe from this group, send an email to:
postgis-unsubscribe at yahoogroups.com
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
