[postgis] pl/pgsql support
Eric Faurot Eric.Faurot at info.unicaen.fr
Thu Jan 10 07:42:32 PST 2002
gispmpf writes:
 > hello all
 > I'm istalling postgis 0.6.2 but , i'm stuck with the pl/pgsql support.
 > I had install postgreSQL 7.1.3 but i don't found plpgsql.so in the
 > /usr/local/pgsql/lib.
 > i just found this: /postgresql-7.1.3/src/pl/plpgsql/src/libplpgsql.so
This is weird... It should be installed correctly with 'make install'.
 > what should i do to fix this and continue with the instalattion?
 > also
 > after this fix what i have to do is:
 > psql mydbGIS
 > mydbGIS# CREATE FUNCTION plpgsql_call_handler() RETURNS OPAQUE AS
 >          '/usr/local/pgsql/lib/plpgsql.so' LANGUAGE 'C';
You'll have to change the path here.
 > mydbGIS#CREATE TRUSTED PROCEDURAL LANGUAGE 'plpgsql' HANDLER
 >         plpgsql_call_handler LANCOMPILER 'PL/pgSQL';
 > #\q
Simpler: you can use:
$ createlang plpgsql yourdbGIS
Add '-L path/to/your/plpgsql/so/file' if it doesn't work, but it
should if postgres is correctly installed. Then:
$ psql -f postgis.sql -d yourdbGIS
Eric.
To unsubscribe from this group, send an email to:
postgis-unsubscribe at yahoogroups.com
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
