[postgis] Viewing mapserver itasca demo layer using postgis
Tyler Mitchell
tmitchell at lignum.com
Mon Jan 21 14:15:31 PST 2002
I think I figured it out! I did not enter in a user value for the
connection information! I had assumed that it would try to use "nobody" at
run-time. Now I'm getting somewhere! Thanks guys.
But now I'm working on expressions. What's wrong with this:
EXPRESSION ([cty_name] = 'Itasca')
It doesn't draw anything. When I comment it out the features draw, but I
can't figure out if the syntax is wrong here or not. I get a bit confused
with the FILTER and EXPRESSION syntax differences - is that an issue here?
Dave Blasby
<dblasby at refrac To: postgis at yahoogroups.com
tions.net> cc:
Fax to:
01/21/2002 Subject: Re: [postgis] Viewing mapserver itasca demo layer using
01:44 PM postgis
Please respond
to postgis
Tyler Mitchell wrote:
> No change. I get all the other shapefile layers showing just fine, but
> none from this file.
> All I've done was run the shp2pgsql, load the sql that it generated, then
> "grant select on ctybdpy to public".
> Then made my changes in the map file according to the online postgis
docs.
> Is there any projection stuff I need to do?
> Has anyone else went through this process, or have a database table that
I
> could load to try this with. I'm not convinced I loaded postgis right -
> but I did it by the book and didn't get any errors. Anything I should
> check?
Perhaps you should try to use it as the postgresql superuser to ensure
that
this isnt a permission problem.
On the other hand, it should be giving you an error if there's a problem
like that.
dave
To unsubscribe from this group, send an email to:
postgis-unsubscribe at yahoogroups.com
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
------------------------ Yahoo! Groups Sponsor ---------------------~-->
Sponsored by VeriSign - The Value of Trust
Pinpoint the right security solution for your company - FREE
Guide from industry leader VeriSign gives you all the facts.
http://us.click.yahoo.com/pCuuSA/WdiDAA/yigFAA/PhFolB/TM
