[postgis] ERROR: parser: parse error at or near "with"
Luis Viveros
ldviveros at lycos.com
Thu Jan 31 06:56:56 PST 2002
José Maria:
dentro del archivo postgis.sql estan las instrucciones que lo que tienes que hacer antes de ejecutar las instrucciones sql.
--- you might have to define the plpgsql language something like;
-- CREATE FUNCTION plpgsql_call_handler () RETURNS OPAQUE AS
-- '/usr/local/pgsql/lib/plpgsql.so' LANGUAGE 'C';
-- CREATE TRUSTED PROCEDURAL LANGUAGE 'plpgsql'
-- HANDLER plpgsql_call_handler
-- LANCOMPILER 'PL/pgSQL';
-- here's some hockey code to test to see if plpgsql is installed
-- if it is, you get a message "plpgsql is installed"
-- otherwise it will give a big error message
Luis Viveros
On Thu, 31 Jan 2002 05:26:12
José María Michia wrote:
>Español:
>Hola!
>Cuando ejecuto "psql -f postgis.sql -d databasename" obtengo los
>siguientes errores:
>1- ERROR: parser: parse error at or near "with"
>2- ERROR: parser: parse error at or near ","
>Estos errores se repiten muchas veces.
>Edite el archivo postgis.sql y elimine todos los with(.........) y todos
>los ,'.......' que traian problemas. Luego:
>psql -f postgis.sql -d databasename OK
>CREATE TABLE geom_test ( gid int4, geom geometry,name varchar(25) );
> OK
>INSERT INTO geom_test ( gid, geom, name ) VALUES ( 1, 'POLYGON((0 0 0,0
>5 0,5 5 0,5 0 0,0 0 0))', '3D Square'); ERROR
>ERROR: Load of file /usr/local/pgsql/lib/contrib/libpostgis.so.0.6
>failed: /usr/local/pgsql/lib/contrib/libpostgis.so.0.6: undefined
>symbol: LocalBufferBlockPointers
>Gracias
>ENGLISH???
>Hello!
># "psql -f postgis.sql -d databasename"
>1- ERROR: parser: parse error at or near "with" (many times)
>2- ERROR: parser: parse error at or near "," (many times)
>In postgis.sql, delete every occurrence of [with(...)] and [,'........']
>try again:
> OK
>Thanks
------------------------ Yahoo! Groups Sponsor ---------------------~-->
Sponsored by VeriSign - The Value of Trust
Pinpoint the right security solution for your company - FREE
Guide from industry leader VeriSign gives you all the facts.
http://us.click.yahoo.com/lWSNbC/WdiDAA/yigFAA/PhFolB/TM
To unsubscribe from this group, send an email to:
postgis-unsubscribe at yahoogroups.com
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
