[postgis-users] Fw: [mapserver-users] Urgent - "imgshape" and MS 3.5/3.6
Alfred Kleva
alfred.kleva at siol.net
Mon Jul 1 14:17:09 PDT 2002
----- Original Message -----
To: <mapserver-users at lists.gis.umn.edu>; <alfred.kleva at siol.net>
Sent: Monday, July 01, 2002 11:01 PM
Subject: Re: Fw: [mapserver-users] Urgent - "imgshape" and MS 3.5/3.6
> Then we need to get the PostGIS folks in on this. Not my area of
> expertise...
> Steve
> Stephen Lime
> Data & Applications Manager
> Minnesota DNR
> 500 Lafayette Road
> St. Paul, MN 55155
> 651-297-2937
> >>> "Alfred Kleva" <alfred.kleva at siol.net> 07/01/02 02:44PM >>>
> I have tested on ShapeFile and PostGIS layer.
> On ShapeFile works OK
> On PostGIS 0.60 layer return error :
> Internal Server Error
> The server encountered an internal error or misconfiguration and was
> unable
> to complete your request.
> Please contact the server administrator, root at localhost and inform them
> of
> the time the error occurred, and anything you might have done that may
> have
> caused the error.
> More information about this error may be available in the server error
> log.
> Alfred Kleva
> From: "Steve Lime" <steve.lime at dnr.state.mn.us>
> To: <mapserver-users at lists.gis.umn.edu>; <robert-fritz at web.de>
> Sent: Monday, July 01, 2002 5:46 PM
> Subject: Re: [mapserver-users] Urgent - "imgshape" and MS 3.5/3.6
> > The bug that was filed via Bugzilla was fixed in version 3.6.1 and
> was
> > correct in the 3.7 development code. I've not tested the full
> > functionality though in some time, so if someone could confirm that
> all
> > is well then that would be helpful.
> > Steve
> > >>> "Robert Fritz" <robert-fritz at web.de> 07/01/02 10:35AM >>>
> > Hello,
> > I try to use "imgshape" to query my maps, but I get either wrong
> data
> > or
> > nothing.
> > Does "imgshape" not work ( see:
"http://mapserver.gis.umn.edu/cgi-bin/wilma_hiliter/mapserver-users/0205/msg
> > 00033.html?line=23#hilite") or do I do a mistake?
> > 1. Is there any Mapserver Version, where "imgshape" works?
> > 2. Does the Mapscript "queryByShape" function works? (is it similar
> to
> > "imgshape"?)
> > Thank you,
> > Robert
