[postgis-users] PostGIS data in mapserver
Tyler Mitchell
themitchells at telus.net
Tue Jul 2 08:09:37 PDT 2002
Could you show us how you defined your layer in the map file? Also, could
you show us the details of your table structure (i.e. field definitions) for
the layer?
On Tuesday 02 July 2002 02:15 am, you wrote:
> Hi all ,
> thanks to Chip, Tommie and Tyler for your help,
> I have something wrong with my configuration of Mapserver.
> Here is the problem :when I add a layer in my map file (which is the demo
> itasca) with a postgis connection type and when I try to visualize it with
> ms ; I obtain a query error from msPOSTGISLayerWhichShapes() executing the
> POSTGIS SQL statement.
> To me, the problem is than my data used SRID 54004 and are world data.
> So if I try to add the data contained in BOX3D (387919.653225817
> 5200489.10287243, 500708...)(this is part of my error message) it doesn't
> correspond to anything in my database.
> Am I right ?
> How can I specify the range to query in ?
