[postgis-users] WKB format
Paul Ramsey pramsey at refractions.net
Thu Jul 4 14:36:13 PDT 2002
Check out the Connection object the getTypeMap() function. That could be
one route. The other route might be via using the SQLData interfaces. I
have not done this myself, so I cannot be more specific or give exact
answers. My attempted solution was the org.postgis.* objects, which
depend on the ascii interfaces and are, as you have noted, not very
fast. I am sure a wkb solution is available, just not sure how to access
it.
David Garnier wrote:
> > OK, poking around a bit in JDBC definitions: the pgsql JDBC driver will
> > try and map unknown types (like wkb) into LONGVARCHAR. This is no good
> > for you, you want an 8bit representation. Add a custom mapping for the
> > wkb type which maps into LONGVARBINARY instead. Then getBytes should
> > work better. (http://lab.applinet.nl/postgresql-jdbc/)
> I think that this page says that custom mappings are not supported. This page refers to 7.1, maybe it is supported in 7.2. I see can't see how this is supposed to work, since the query will return an Hex string anyway.
> (My head feels dizzy from reading Postgresql source code, so maybe I just can't see the obvious).
> Could you be a bit more specific (source code for example) about binary cursors and libpq? Postgresql has a a FastPath API that allows the user to call procedures on the backend.
> Best regards,
> David Garnier
> > (My query to Dave and Chris remains.)
> > Paul Ramsey wrote:
> > > Poke around some more. My guess is that this problem adheres to the JDBC
> > > driver in some manner. We can retrieve WKB directly from binary cursors
> > > with no problem via libpq. It could be that pgsql is squashing the
> > > results of the WKB query into 7 bits because it is not a known 8bit
> > > type, and the cursor is not 8bit. Can you do clean getBytes against
> > > bytea types using text cursors?
> > > Perhaps Dave/Chris could answer: why are we using a special type (wkb)
> > > for the wkb results instead of just a bytea?
> > > P.
> > > > OK, I think I get it from reading the source. PostGIS actually parses the binary data into an hexadecimal string and returns it. If I try to read my data with a getString, it looks fine, just like in plsql.
> > > > Now, there is a way to get the real bytes? A byte array that would match the specification of the WKB format? Or are we stuck with Strings till the end of times?
> > > > Best Regards,
> > > > David Garnier
> > > > On Thu, 4 Jul 2002 21:24:18 +0200
> > > > David Garnier <david.garnier at etudier-online.com> wrote:
> > > > > Hello,
> > > > > I'm working on this WKBReader in java, and I have some problems getting the data out of postgres. I use the following query:
> > > > > select asbinary(the_geom,'NDR') as wkb , astext(the_geom) as wkt  from road_shapes limit 25
> > > > > Then I do a getBytes on wkb:
> > > > > From java I got this: 303130353030303030303031303030303030303130323030303030303033303030303030373532324331353433334641353943303130354130463546323630303434343034324231313533343244464235394330334132313734443032353030343434303734354643453643353746433539433032334639344132303235303034343430
> > > > > From plsql, I got this:
> > > > > 0105000000010000000102000000030000007522C15433FA59C0105A0F5F2600444042B115342DFB59C03A2174D025004440745FCE6C57FC59C023F94A2025004440
> > > > > I think that there is two problems: the fourth bit of the each byte is set null. That would explain why there is no values above 7.
> > > > > I'm thinking that this might be related to different encoding schemes between Java and postgres.
> > > > > I figured that I would just ask around before diving head first into the source code of postgis.
> > > > > Best Regards,
> > > > > David Garnier
> > > > > _______________________________________________
> > > > > postgis-users mailing list
> > > > > postgis-users at postgis.refractions.net
> > > > > http://postgis.refractions.net/mailman/listinfo/postgis-users
> > >       __
> > >      | Paul Ramsey
> > >      | Refractions Research
> > >      | Email: pramsey at refractions.net
> > >      | Phone: (250) 885-0632
> > >      \_
> >       __
> >      | Paul Ramsey
> >      \_
      __
     | Paul Ramsey
     \_
