[postgis-users] flow direction (pointer) indexing
Paul Ramsey pramsey at refractions.net
Fri Jul 5 10:18:48 PDT 2002
This sounds alot more like a GRASS / raster GIS problem than a spatial
DB problem. Why do you think a spatial DB is the right tool for this
analysis? Is the data volume unmanageable by a GIS? Or is there a data
management issue in addition to the data analysis issue which makes the
spatial DB a good choice? I like seeing people working with PostGIS, but
I am loath to recommend a saw when a hammer might be better suited... :/
P.
"Robert W. Burgholzer" wrote:
> Steffan/list,
> Ultimately my goal is to describe runoff from rainfall events. Basically
> what I am focusing on is overland flow, that is, in a stream network, or
> perhaps as a sheet (with an assumption of uniform flow across several
> cells). I will be creating the networks in all cases as a consequence of
> elevation differences in adjacent cells. It is the storage of references
> to adjacent flow cells which I am concerned about.
> As a consequence of elevation differences from cell to cell, a network
> could be established by giving a spatial reference for the outlet and
> inlet cells in the data table of the cell. This is as you describe, and
> what I call a "pointer approach". This approach is valid for the case in
> which you have flow which I'll call concentrated flow. The second case
> that I see is one in which we have a sheet flow which may be described
> by using a finite difference/element technique to solve a flow equation
> numerically over several cells simultaneously. In this case, we must
> know the flow depth in at least 2 adjacent cells. We can still use this
> pointer approach in this case. My assumption is that the pointers would
> be best done on an id column in this case.
> A second approach would be to calculate flow direction on the fly using
> the elevation of the current cell, and concept of the 'hydraulic head'
> in the cell, which would allow a more flexible situation, such as one
> which represents the overtopping of terraces and other flow control
> structures. The hydraulic head would be a vector pointing in the
> direction that flow "wants" to occur (based on elevation differences),
> and the elevation of the water surface in the cell  relative to the
> adjacent cells would determine if flow WOULD occur into a cell or not.
> In this case, I believe I would need to do it spatially.
> I will elaborate in SQL the cases I face:
> CASE 1: POINTER APPROACH - STREAM NETWORK IS CALCULATED BEFOREHAND
> select sum(b.qout) as inflow,a.gid from minihup as a,minihup as b where
> a.gid = b.outletcell
>        group by a.gid;
> CASE 2: HYDRAULIC HEAD APPROACH
> select a.depth,b.surface_elevation,a.roughness,a.slope from landtheme as
> a,
>        landtheme as b where a.contribcell_geom1 &&
> b.hydraulic_head_vector
>        and a.surface_elevation <= b.surface_elevation
> My question would be, in case 1, do I do an index on the gid column and
> be done with it? Or should I do some sort of spatial index, and/or some
> type of narrowing query to say "only need to search adjacent cells". In
> CASE 2, is the spatial index sufficient (GIST) or do I need to do more?
> I hope I was clear here, I am interested in any thouguhts.
> Steffen Macke wrote:
> > > I am interested in an indexing scheme that will order line segments and
> > > polyogn "cells" by a flow network, for the purposes of optimizing
> > > hydrologic models done uysing postgis.
> > I've used a simple 'on-the-fly topology' water and wastewater networks
> > consisting of lines and nodes in ArcView. The flow direction is simply
> > defined by the digitizing direction of the line. If the flow direction
> > changes, you have to flip the line. Traces through the network look
> > up nodes and lines connected at the start and end points of a line.
> > While the performance of this approach is not optimal, it is a very
> > simple and intuitive way of storing the information. It should also
> > be quite easy to visualize the flow direction. As PostGIS allows multiple
> > geometry columns, you can add the start and end points of the lines
> > as separate columns, which could help to improve the performance (depending
> > on how many vertices your lines contain).
> > How do you create/edit your networks? I'm currently trying to implement a
> > network editor for water/wastewater networks in Java that uses PostGIS
> > for storage.
> > Steffen
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
> Robert Burgholzer
> al·go·rithm  n.
>        A step-by-step problem-solving procedure, especially an
> established, recursive computational
>        procedure for solving a problem in a finite number of steps.
> Invented by Al Gore.
> rburghol at vt.edu
> http://www.soulswimmer.net/
