[postgis-users] postgis type define error
Hao Ding
hdi12 at it.canterbury.ac.nz
Sun Jul 7 20:26:01 PDT 2002
Hi all,
One problem have troubled me for several days. I installed mapserver
3.6.1, postgresql 7.2.1, and postgis 0.7.1. when querying a map using
itasca demo application, I got a error message:
msPOSTGISLayerWhichShapes(): Query error. prep_DB:Error executing
POSTGIS DECLARE statement (0.6 failed - retried 0.5 and it failed too).
DECLARE mycursor BINARY CURSOR FOR SELECT
asbinary(force_collection(force_2d(the_geom)),'NDR'),OID::text from
airports WHERE the_geom && setSRID('BOX3D(388013.643812817
5200395.13465842,500802.348432817 5313156.99196842)'::BOX3D,
find_srid('','airports','the_geom') )
and in the log file, I found error record:
ERROR: Unable to identify an operator '&&' for types 'geometry' and
'geometry'
You will have to retype this query using an explicit cast
ERROR: Unable to identify an operator '&&' for types 'geometry' and 'box3d'
pq_recvbuf: unexpected EOF on client connection
I guess the problem could be the type 'geometry' and 'box3d' were not
identified. I then dropped my database and created again.
createdb gisdb
createlang plpgsql gisdb
psql -d gisdb -f .../postgis.sql
I found some warning notes at this point:
psql:/home/cosc/studPG/hdi12/pgsql/share/contrib/postgis.sql:218:
NOTICE:ProcedureCreate: type 'box3d' is not yet defined
psql:/home/cosc/studPG/hdi12/pgsql/share/contrib/postgis.sql:228:
NOTICE:ProcedureCreate: type 'spheroid' is not yet defined
psql:/home/cosc/studPG/hdi12/pgsql/share/contrib/postgis.sql:252:
NOTICE:ProcedureCreate: type 'wkb' is not yet defined
psql:/home/cosc/studPG/hdi12/pgsql/share/contrib/postgis.sql:273:
NOTICE:ProcedureCreate: type 'chip' is not yet defined
psql:/home/cosc/studPG/hdi12/pgsql/share/contrib/postgis.sql:338:
NOTICE:ProcedureCreate: type 'geometry' is not yet defined
psql:/home/cosc/studPG/hdi12/pgsql/share/contrib/postgis.sql:819:
ERROR:OperatorDef: function 'postgis_gist_sel(oid, oid, int2, opaque,
int4)' does not exist
psql:/home/cosc/studPG/hdi12/pgsql/share/contrib/postgis.sql:825:
NOTICE:current transaction is aborted, queries ignored until end of
transaction block
*ABORT STATE*
psql:/home/cosc/studPG/hdi12/pgsql/share/contrib/postgis.sql:831:
transaction block
*ABORT STATE*
psql:/home/cosc/studPG/hdi12/pgsql/share/contrib/postgis.sql:837:
transaction block
*ABORT STATE*
Obviously the type 'geometry', 'box3d', and many other things
were not defined.
Can anyone tell me how to solve the problem? Any suggestions would be
very appreciated.
Regards!
Hao
