[postgis-users] Installing PostGIS - problem
Hao Ding
hdi12 at it.canterbury.ac.nz
Tue Jul 9 16:19:56 PDT 2002
Hi Alan,
I met the similar problem as you and have not solved it so far. Did you got
the idea to deal with it? If yes, could you please tell me?
Regards,
Hao
>===== Original Message From postgis-users at postgis.refractions.net =====
>Hi,
>I have installed postgresql OK (Redhat Linux).
>When installing PostGIS all goes well until
>psql -d yourdatabase -f postgis.sql
>Below is the log file showing notices and errors. Any suggestions would be
appreciated.
>Regards,
>Alan
>020705.16:38:40.104 [10646] DEBUG: Data Base System is starting up at Fri
Jul 5 16:38:40 2002
>020705.16:38:40.104 [10646] DEBUG: Data Base System was shut down at Fri Jul
5 16:38:27 2002
>020705.16:38:40.106 [10646] DEBUG: Data Base System is in production state
at Fri Jul 5 16:38:40 2002
>020705.16:38:54.528 [10649] NOTICE: CREATE TABLE/PRIMARY KEY will create
implicit index 'spatial_ref_sys_pkey' for table 'spatial_ref_sys'
>020705.16:38:54.543 [10649] NOTICE: CREATE TABLE/PRIMARY KEY will create
implicit index 'gc_pk' for table 'geometry_columns'
>020705.16:38:54.556 [10649] NOTICE: Unrecognized function attribute
'isstrict' ignored
>020705.16:38:54.562 [10649] NOTICE: Unrecognized function attribute
'isstrict' ignored
>020705.16:38:54.567 [10649] NOTICE: Unrecognized function attribute
'isstrict' ignored
>020705.16:38:54.571 [10649] NOTICE: Unrecognized function attribute
'isstrict' ignored
>020705.16:38:54.575 [10649] NOTICE: Unrecognized function attribute
'isstrict' ignored
>020705.16:38:54.577 [10649] NOTICE: ProcedureCreate: type 'box3d' is not yet
defined
>020705.16:38:54.582 [10649] NOTICE: Unrecognized function attribute
'isstrict' ignored
>020705.16:38:54.586 [10649] NOTICE: Unrecognized function attribute
'isstrict' ignored
>020705.16:38:54.588 [10649] NOTICE: ProcedureCreate: type 'spheroid' is not
yet defined
>020705.16:38:54.592 [10649] NOTICE: Unrecognized function attribute
'isstrict' ignored
>020705.16:38:54.601 [10649] NOTICE: Unrecognized function attribute
'isstrict' ignored
>020705.16:38:54.603 [10649] NOTICE: ProcedureCreate: type 'wkb' is not yet
defined
>020705.16:38:54.608 [10649] NOTICE: Unrecognized function attribute
'isstrict' ignored
>020705.16:38:54.612 [10649] NOTICE: DefineType: attribute "storage" not
recognized
>020705.16:38:54.617 [10649] NOTICE: Unrecognized function attribute
'isstrict' ignored
>020705.16:38:54.619 [10649] NOTICE: ProcedureCreate: type 'chip' is not yet
defined
>020705.16:38:54.623 [10649] NOTICE: Unrecognized function attribute
'isstrict' ignored
>020705.16:38:54.627 [10649] NOTICE: DefineType: attribute "storage" not
recognized
>020705.16:38:54.632 [10649] NOTICE: Unrecognized function attribute
'isstrict' ignored
>020705.16:38:54.636 [10649] NOTICE: Unrecognized function attribute
'isstrict' ignored
>020705.16:38:54.640 [10649] NOTICE: Unrecognized function attribute
'isstrict' ignored
>020705.16:38:54.644 [10649] NOTICE: Unrecognized function attribute
'isstrict' ignored
>020705.16:38:54.648 [10649] NOTICE: Unrecognized function attribute
'isstrict' ignored
>020705.16:38:54.652 [10649] NOTICE: Unrecognized function attribute
'isstrict' ignored
>020705.16:38:54.656 [10649] NOTICE: Unrecognized function attribute
'isstrict' ignored
>020705.16:38:54.660 [10649] NOTICE: Unrecognized function attribute
'isstrict' ignored
>020705.16:38:54.664 [10649] NOTICE: Unrecognized function attribute
'isstrict' ignored
>020705.16:38:54.666 [10649] NOTICE: ProcedureCreate: type 'geometry' is not
yet defined
>020705.16:38:54.671 [10649] NOTICE: Unrecognized function attribute
'isstrict' ignored
>020705.16:38:54.675 [10649] NOTICE: DefineType: attribute "storage" not
recognized
>020705.16:38:54.679 [10649] NOTICE: Unrecognized function attribute
'isstrict' ignored
>020705.16:38:54.684 [10649] NOTICE: Unrecognized function attribute
'isstrict' ignored
>020705.16:38:54.688 [10649] NOTICE: Unrecognized function attribute
'isstrict' ignored
>020705.16:38:54.692 [10649] NOTICE: Unrecognized function attribute
'isstrict' ignored
>020705.16:38:54.696 [10649] NOTICE: Unrecognized function attribute
'isstrict' ignored
>020705.16:38:54.700 [10649] NOTICE: Unrecognized function attribute
'isstrict' ignored
>020705.16:38:54.705 [10649] NOTICE: Unrecognized function attribute
'isstrict' ignored
>020705.16:38:54.709 [10649] NOTICE: Unrecognized function attribute
'isstrict' ignored
>020705.16:38:54.713 [10649] NOTICE: Unrecognized function attribute
'isstrict' ignored
>020705.16:38:54.718 [10649] NOTICE: Unrecognized function attribute
'isstrict' ignored
>020705.16:38:54.722 [10649] NOTICE: Unrecognized function attribute
'isstrict' ignored
>020705.16:38:54.724 [10649] NOTICE: Unrecognized function attribute
'isstrict' ignored
>020705.16:38:54.725 [10649] NOTICE: Unrecognized function attribute
'isstrict' ignored
'isstrict' ignored
'isstrict' ignored
>020705.16:38:54.726 [10649] NOTICE: Unrecognized function attribute
'isstrict' ignored
'isstrict' ignored
>020705.16:38:54.727 [10649] NOTICE: Unrecognized function attribute
'isstrict' ignored
'isstrict' ignored
>020705.16:38:54.728 [10649] NOTICE: Unrecognized function attribute
'isstrict' ignored
'isstrict' ignored
>020705.16:38:54.729 [10649] NOTICE: Unrecognized function attribute
'isstrict' ignored
'isstrict' ignored
>020705.16:38:54.730 [10649] NOTICE: Unrecognized function attribute
'isstrict' ignored
'isstrict' ignored
>020705.16:38:54.731 [10649] NOTICE: Unrecognized function attribute
'isstrict' ignored
'isstrict' ignored
>020705.16:38:54.732 [10649] NOTICE: Unrecognized function attribute
'isstrict' ignored
'isstrict' ignored
>020705.16:38:54.733 [10649] NOTICE: Unrecognized function attribute
'isstrict' ignored
'isstrict' ignored
>020705.16:38:54.739 [10649] NOTICE: Unrecognized function attribute
'isstrict' ignored
>020705.16:38:54.743 [10649] NOTICE: Unrecognized function attribute
'isstrict' ignored
>020705.16:38:54.747 [10649] NOTICE: Unrecognized function attribute
'isstrict' ignored
>020705.16:38:54.751 [10649] NOTICE: Unrecognized function attribute
'isstrict' ignored
>020705.16:38:54.755 [10649] NOTICE: Unrecognized function attribute
'isstrict' ignored
>020705.16:38:54.760 [10649] NOTICE: Unrecognized function attribute
'isstrict' ignored
>020705.16:38:54.764 [10649] NOTICE: Unrecognized function attribute
'isstrict' ignored
'isstrict' ignored
>020705.16:38:54.765 [10649] NOTICE: Unrecognized function attribute
'isstrict' ignored
'isstrict' ignored
>020705.16:38:54.766 [10649] NOTICE: Unrecognized function attribute
'isstrict' ignored
'isstrict' ignored
>020705.16:38:54.767 [10649] NOTICE: Unrecognized function attribute
'isstrict' ignored
'isstrict' ignored
>020705.16:38:54.768 [10649] NOTICE: Unrecognized function attribute
'isstrict' ignored
'isstrict' ignored
>020705.16:38:54.769 [10649] NOTICE: Unrecognized function attribute
'isstrict' ignored
'isstrict' ignored
'isstrict' ignored
>020705.16:38:54.770 [10649] NOTICE: Unrecognized function attribute
'isstrict' ignored
'isstrict' ignored
>020705.16:38:54.771 [10649] NOTICE: Unrecognized function attribute
'isstrict' ignored
'isstrict' ignored
>020705.16:38:54.772 [10649] NOTICE: Unrecognized function attribute
'isstrict' ignored
'isstrict' ignored
>020705.16:38:54.773 [10649] NOTICE: Unrecognized function attribute
'isstrict' ignored
'isstrict' ignored
>020705.16:38:54.782 [10649] NOTICE: DefineAggregate: attribute "sfunc" not
recognized
>020705.16:38:54.783 [10649] NOTICE: DefineAggregate: attribute "stype" not
recognized
>020705.16:38:54.783 [10649] ERROR: AggregateCreate: aggregate must have at
least one transition function
>020705.16:38:54.786 [10649] NOTICE: current transaction is aborted, queries
ignored until end of transaction block
>020705.16:38:54.787 [10649] NOTICE: current transaction is aborted, queries
>020705.16:38:54.788 [10649] NOTICE: current transaction is aborted, queries
>020705.16:38:54.789 [10649] NOTICE: current transaction is aborted, queries
>020705.16:38:54.790 [10649] NOTICE: current transaction is aborted, queries
>020705.16:38:54.791 [10649] ERROR: ProcedureCreate: arg type 'geometry' is
not defined
>020705.16:38:54.791 [10649] NOTICE: current transaction is aborted, queries
>020705.16:38:54.792 [10649] NOTICE: current transaction is aborted, queries
>020705.16:38:54.793 [10649] NOTICE: current transaction is aborted, queries
>020705.16:38:54.794 [10649] NOTICE: current transaction is aborted, queries
>020705.16:38:54.796 [10649] NOTICE: current transaction is aborted, queries
>020705.16:38:54.797 [10649] NOTICE: current transaction is aborted, queries
>020705.16:38:54.798 [10649] NOTICE: current transaction is aborted, queries
>020705.16:38:54.799 [10649] ERROR: Relation 'pg_opclass' does not have
attribute 'opcamid'
>020705.16:38:54.799 [10649] NOTICE: current transaction is aborted, queries
>020705.16:38:54.800 [10649] ERROR: Relation 'rt_ops_tmp' does not exist
>020705.16:38:54.801 [10649] ERROR: Relation 'rt_ops_tmp' does not exist
>020705.16:38:54.802 [10649] ERROR: Relation 'rt_ops_tmp' does not exist
>020705.16:38:54.802 [10649] NOTICE: current transaction is aborted, queries
>020705.16:38:54.803 [10649] ERROR: Attribute 'opcamid' not found
>020705.16:38:54.804 [10649] ERROR: Attribute 'opcamid' not found
>020705.16:38:54.805 [10649] ERROR: Attribute 'opcamid' not found
>020705.16:38:54.806 [10649] ERROR: Attribute 'opcamid' not found
