[postgis-users] WKB4J
Dave Blasby
dblasby at refractions.net
Mon Jul 29 09:44:22 PDT 2002
David Garnier wrote:
> WKB4J is a small Java toolkit designed to parse WKB data stored in a PostGIS database and convert it into Java objects. WKB4J implements the Simple Features Specification for SQL as defined by the OpenGIS consortium.
Excellent - I'm looking forward to checking this out!
Are you handling 3d points? PostGIS (and several other WKB-producing
Open Source projects) are adding 80x (128 decimal) to the WKB type and
then putting in 3 doubles for points (x,y,z).
dave
