[postgis-users] WKB4J
Paul Ramsey pramsey at refractions.net
Mon Jul 29 10:24:14 PDT 2002
The reference we used originally was this proposal.
http://gdal.velocet.ca/projects/opengis/twohalfdsf.html
Dave Blasby wrote:
> David Garnier wrote:
> > > Are you handling 3d points?  PostGIS (and several other WKB-producing
> > > Open Source projects) are adding 80x (128 decimal) to the WKB type and
> > > then putting in 3 doubles for points (x,y,z).
> > Well right now it doesn't, but it would just require one switch case and 3 more methods in the Factory interface. Do you have a reference where I could learn more about this?
> There isnt a reference for it, unfortunately.
> PostGIS will produce 3D WKB by default if there are 3d points in the
> geometric object.
> For example,
> > SELECT asBinary('POINT(0 1 2)');
> > SELECT asBinary('LINESTRING(0 0 0, 1 1 1)');
> Note; you can convert a 3d geometry into a 2d geometry by calling the
> force_2d() function on it:
> > SELECT force_2d('POINT(0 1 2)');
>         -> POINT(0 1)
> > SELECT force_2d('LINESTRING(0 0 0, 1 1 1)');
>         -> LINESTRING(0 0, 1 1)
> enum wkbGeometryType {
> wkbPoint = 1,
> wkbLineString = 2,
> wkbPolygon = 3,
> wkbMultiPoint = 4,
> wkbMultiLineString = 5,
> wkbMultiPolygon = 6,
> wkbGeometryCollection = 7,
> wkbPoint3d = 129,
> wkbLineString3d = 130,
> wkbPolygon3d = 131,
> wkbMultiPoint3d = 132,
> wkbMultiLineString3d = 133,
> wkbMultiPolygon3d = 134,
> wkbGeometryCollection3d = 135
> Point {
> double x;
> double y;
> Point3d {
> double x;
> double y;
> double z;
> postgis-users mailing list
      __
     | Paul Ramsey
     | Refractions Research
     | Email: pramsey at refractions.net
     | Phone: (250) 885-0632
     \_
