[postgis-users] sql works, but not as layer?
Twan Kogels twan at twansoft.com
Tue Jun 4 06:35:21 PDT 2002
Hello,
I've got 2 tables in my postgresql database, 1 table (pc6punten) contains
zipcodes including a MULTIPOINT. The second table consists of infomation
related to the zipcode.
Now i want to join both tables to display the zipcode points on a map (with
mapserver).
So i constructed a sql query:
select the_geom, * from objecteigenschappen o left join pc6punten p on
p.pc6=o.eigenschap_3 where (the_geom && GeometryFromText('BOX3D(109258
559953,115258 565953)'::box3d,-1) and distance(the_geom,
GeometryFromText('POINT(112258 562953)',-1)) < 3000)
When i execute this query directly in postgresql (with psql client) it
works correct and returns the correct records.
But when i create a mapserver postgis layer in the map file:
CONNECTION "user=postgres dbname=food host=10.0.0.2"
DATA "the_geom from objecteigenschappen o left join pc6punten p on
p.pc6=o.eigenschap_3"
FILTER "(the_geom && GeometryFromText('BOX3D(109258 559953,115258
565953)'::box3d,-1) and distance(the_geom, GeometryFromText('POINT(112258
562953)',-1)) < 3000)"
postgresql return a:
"ERROR:  Attribute 'oid' not found"
(i have made a oid index on the pc6punten and objecteigenschappen table)
mapserver returns a:
"Warning: MapServer Error in msPOSTGISLayerWhichShapes(): prep_DB:Error
executing POSTGIS DECLARE statement (0.6 failed - retried 0.5 and it failed
too). in /usr/local/apache/htdocs/food/food/kaart.php on line x"
A mapserver postgis layer like:
DATA "the_geom from pc6punten"
FILTER "pc6 like '1797%'
returns without errors and with the correct results.
I suspect the error is related with the "left join" function, but i can't
seem to find what i'm doing wrong.
Any ideas what is going wrong?
Best regards,
-twan
http://www.twansoft.com
