[postgis-users] PostGIS 0.7 Released
Paul Ramsey pramsey at refractions.net
Sat May 4 16:25:12 PDT 2002
PostGIS - http://postgis.refractions.net
Refractions Research is pleased to announce the 0.7
release of PostGIS : Geographic Objects for PostgreSQL.
PostGIS/PostgreSQL is a spatial database much like
ESRI's SDE and Oracle's OracleSpatial. PostGIS is
open-source software licenced under the GNU LGPL.
PostGIS/PostgreSQL includes the following functionality:
- Simple Features as defined by the OpenGIS
  Consortium (OGC)
- Support for Well-Known Text and Well-Known Binary
  representations of GIS objects
- Fast spatial indexing using GiST
- Geospatial analysis functions
- PostgreSQL JDBC extension objects corresponding
  to the geometries
- Support for OGC access functions as defined by the
  Simple Features Specification
- Accessible from UMN Mapserver version 3.5
  (http://mapserver.gis.umn.edu)
Changes in 0.7:
- New Things
  - support for PostgreSQL 7.2 GiST index API
  - transform() function provides coordinate
    reprojection using proj4 library
  - spatial_ref_sys.sql has a complete set of proj4
    definitions for each EPSG coordinate system
  - refactoring of source code to separate index support
    functions from other functions
  - max_distance() function
  - distance_spheroid() function
  - collect() aggregate function
  - xmin(),ymin(),zmin(),xmax(),ymax(),zmax()
- Bug Fixes
  - several patches to loader/dumper
  - transform() more graceful when grid shifts
    are missing
  - setsrid() made cachable
