AW: [postgis-users] Re: [postgis-users] Compilation error Postgis 0.7
Düster Horst
Horst.Duester at bd.so.ch
Mon May 6 04:18:01 PDT 2002
Hallo Giuseppe
Thank you for your hint. Now it works fine.
Horst
-----Ursprüngliche Nachricht-----
Von: Giuseppe Sacco [mailto:eppesuigoccas at libero.it]
Gesendet am: Montag, 6. Mai 2002 10:52
An: postgis-users at postgis.refractions.net
Betreff: [postgis-users] Re: [postgis-users] Compilation error Postgis
0.7
> Hallo
> When I compile Postgis 0.7 it arises the following error:
> postgis_gist.c: In function `ggeometry_compress':
> postgis_gist.c:104: structure has no member named `pred'
You need to set te PG_72 variable in postgis/Makefile to 1.
Bye,
Giuseppe
¦<-'+.±êì(tm)¨¥Sx%SËi¢Ë`Sˬz»)¢Ë`SÊÞ~¶oe¶*'²w?Ûiÿúh²Ø"²·Y§-S?ìë(tm)¨¥(tm
)©ÿ-+-Swèþs,¶¬ºÇ«
