[postgis-users] PostGIS 0.7 another compilation error
Paul Ramsey pramsey at refractions.net
Tue May 7 08:29:25 PDT 2002
It appears to be gods ugliest define (some function inlining gone awry).
What gcc are you using? This compiles on Mandrake 8, under gcc 2.96
(2.96??). We'll see if we can clean that up somehow.
Oliver Heimann wrote:
> i also tried to compile PostGIS 0.7 against PostgreSQL 7.2 and 7.2.1 but
> i got errors too.
> I tried to compile it under SuSE Linux 8.0 and Sun Solaris 8.
> When i compile PostGIS 0.7 against PostgreSQL 7.1.3 (USE_PG72=0) all
> works fine.
> It seems to be a problem with GIST.?
> Greetings
> Oliver
> Solaris 8 (SPARC)
> PostgreSQL 7.2
> USE_PG72=1
> gcc  -Wall -Wmissing-prototypes -Wmissing-declarations -fPIC -g  -I.
> -I../../src/include  -DFRONTEND
> -DSYSCONFDIR='"/export/free/uopt/postgresql/aktuell/etc"'   -c -o
> postgis_gist_72.o postgis_gist_72.c
> postgis_gist_72.c:189: warning: no previous prototype for
> `rtree_decompress'
> postgis_gist_72.c: In function `gbox_picksplit':
> postgis_gist_72.c:370: `pos' undeclared (first use in this function)
> postgis_gist_72.c:370: (Each undeclared identifier is reported only once
> postgis_gist_72.c:370: for each function it appears in.)
> postgis_gist_72.c:370: stray '\' in program
> postgis_gist_72.c:371: `unionD' undeclared (first use in this function)
> postgis_gist_72.c:371: stray '\' in program
> postgis_gist_72.c:372: stray '\' in program
> postgis_gist_72.c:373: stray '\' in program
> postgis_gist_72.c:374: stray '\' in program
> postgis_gist_72.c:375: stray '\' in program
> postgis_gist_72.c:376: stray '\' in program
> postgis_gist_72.c:377: stray '\' in program
> postgis_gist_72.c:378: `list' undeclared (first use in this function)
> postgis_gist_72.c:378: stray '\' in program
> postgis_gist_72.c:379: stray '\' in program
> postgis_gist_72.c:286: warning: unused variable `direction'
> postgis_gist_72.c:380: warning: control reaches end of non-void function
> postgis_gist_72.c: At top level:
> postgis_gist_72.c:380: parse error before `while'
> postgis_gist_72.c:382: warning: type defaults to `int' in declaration of
> `i'
> postgis_gist_72.c:382: initializer element is not constant
> postgis_gist_72.c:382: parse error before `)'
> postgis_gist_72.c:386: stray '\' in program
> postgis_gist_72.c:388: stray '\' in program
> postgis_gist_72.c:390: stray '\' in program
> postgis_gist_72.c:392: stray '\' in program
> postgis_gist_72.c:407: `unionB' undeclared here (not in a function)
> postgis_gist_72.c:408: `unionT' undeclared here (not in a function)
> postgis_gist_72.c:408: initializer element is not constant
> postgis_gist_72.c:412: warning: type defaults to `int' in declaration of
> `sizeLR'
> postgis_gist_72.c:412: conflicting types for `sizeLR'
> postgis_gist_72.c:409: previous declaration of `sizeLR'
> postgis_gist_72.c:412: `interLR' undeclared here (not in a function)
> postgis_gist_72.c:412: initializer element is not constant
> postgis_gist_72.c:412: warning: data definition has no type or storage
> class
> postgis_gist_72.c:413: warning: type defaults to `int' in declaration of
> `sizeBT'
> postgis_gist_72.c:413: conflicting types for `sizeBT'
> postgis_gist_72.c:410: previous declaration of `sizeBT'
> postgis_gist_72.c:413: initializer element is not constant
> postgis_gist_72.c:413: warning: data definition has no type or storage
> class
> postgis_gist_72.c:415: parse error before `if'
> postgis_gist_72.c:424: warning: type defaults to `int' in declaration of
> `pfree'
> postgis_gist_72.c:424: warning: parameter names (without types) in
> function declaration
> postgis_gist_72.c:424: conflicting types for `pfree'
> ../../src/include/utils/palloc.h:52: previous declaration of `pfree'
> postgis_gist_72.c:424: warning: data definition has no type or storage
> class
> postgis_gist_72.c:425: warning: type defaults to `int' in declaration of
> `pfree'
> postgis_gist_72.c:425: warning: parameter names (without types) in
> postgis_gist_72.c:425: warning: data definition has no type or storage
> class
> postgis_gist_72.c:426: warning: type defaults to `int' in declaration of
> `pfree'
> postgis_gist_72.c:426: warning: parameter names (without types) in
> postgis_gist_72.c:426: warning: data definition has no type or storage
> class
> postgis_gist_72.c:428: parse error before `->'
> postgis_gist_72.c:438: warning: type defaults to `int' in declaration of
> `pfree'
> postgis_gist_72.c:438: warning: parameter names (without types) in
> postgis_gist_72.c:438: warning: data definition has no type or storage
> class
> postgis_gist_72.c:439: warning: type defaults to `int' in declaration of
> `pfree'
> postgis_gist_72.c:439: warning: parameter names (without types) in
> postgis_gist_72.c:439: warning: data definition has no type or storage
> class
> postgis_gist_72.c:440: warning: type defaults to `int' in declaration of
> `pfree'
> postgis_gist_72.c:440: warning: parameter names (without types) in
> postgis_gist_72.c:440: warning: data definition has no type or storage
> class
> postgis_gist_72.c:442: parse error before `->'
> postgis_gist_72.c:482: warning: `gbox_leaf_consistent' defined but not
> used
> gmake: *** [postgis_gist_72.o] Error 1
> postgis-users mailing list
