[postgis-users] PostGIS 0.7 another compilation error
Paul Ramsey
pramsey at refractions.net
Tue May 7 08:35:33 PDT 2002
I have a hunch.
Run this perl script on the file thusly and then try again:
perl undos.pl postgis_gist_72.c > out ; mv out postgis_gist_72.c
-- undos.pl
while(<>) {
s/\r\n/\n/;
print;
Oliver Heimann wrote:
> Hi,
> i also tried to compile PostGIS 0.7 against PostgreSQL 7.2 and 7.2.1 but
> i got errors too.
> I tried to compile it under SuSE Linux 8.0 and Sun Solaris 8.
> When i compile PostGIS 0.7 against PostgreSQL 7.1.3 (USE_PG72=0) all
> works fine.
> It seems to be a problem with GIST.?
> Greetings
> Oliver
> Solaris 8 (SPARC)
> PostgreSQL 7.2
> USE_PG72=1
> gcc -Wall -Wmissing-prototypes -Wmissing-declarations -fPIC -g -I.
> -I../../src/include -DFRONTEND
> -DSYSCONFDIR='"/export/free/uopt/postgresql/aktuell/etc"' -c -o
> postgis_gist_72.o postgis_gist_72.c
> postgis_gist_72.c:189: warning: no previous prototype for
> `rtree_decompress'
> postgis_gist_72.c: In function `gbox_picksplit':
> postgis_gist_72.c:370: `pos' undeclared (first use in this function)
> postgis_gist_72.c:370: (Each undeclared identifier is reported only once
> postgis_gist_72.c:370: for each function it appears in.)
> postgis_gist_72.c:370: stray '\' in program
> postgis_gist_72.c:371: `unionD' undeclared (first use in this function)
> postgis_gist_72.c:371: stray '\' in program
> postgis_gist_72.c:372: stray '\' in program
> postgis_gist_72.c:373: stray '\' in program
> postgis_gist_72.c:374: stray '\' in program
> postgis_gist_72.c:375: stray '\' in program
> postgis_gist_72.c:376: stray '\' in program
> postgis_gist_72.c:377: stray '\' in program
> postgis_gist_72.c:378: `list' undeclared (first use in this function)
> postgis_gist_72.c:378: stray '\' in program
> postgis_gist_72.c:379: stray '\' in program
> postgis_gist_72.c:286: warning: unused variable `direction'
> postgis_gist_72.c:380: warning: control reaches end of non-void function
> postgis_gist_72.c: At top level:
> postgis_gist_72.c:380: parse error before `while'
> postgis_gist_72.c:382: warning: type defaults to `int' in declaration of
> `i'
> postgis_gist_72.c:382: initializer element is not constant
> postgis_gist_72.c:382: parse error before `)'
> postgis_gist_72.c:386: stray '\' in program
> postgis_gist_72.c:388: stray '\' in program
> postgis_gist_72.c:390: stray '\' in program
> postgis_gist_72.c:392: stray '\' in program
> postgis_gist_72.c:407: `unionB' undeclared here (not in a function)
> postgis_gist_72.c:408: `unionT' undeclared here (not in a function)
> postgis_gist_72.c:408: initializer element is not constant
> postgis_gist_72.c:412: warning: type defaults to `int' in declaration of
> `sizeLR'
> postgis_gist_72.c:412: conflicting types for `sizeLR'
> postgis_gist_72.c:409: previous declaration of `sizeLR'
> postgis_gist_72.c:412: `interLR' undeclared here (not in a function)
> postgis_gist_72.c:412: initializer element is not constant
> postgis_gist_72.c:412: warning: data definition has no type or storage
> class
> postgis_gist_72.c:413: warning: type defaults to `int' in declaration of
> `sizeBT'
> postgis_gist_72.c:413: conflicting types for `sizeBT'
> postgis_gist_72.c:410: previous declaration of `sizeBT'
> postgis_gist_72.c:413: initializer element is not constant
> postgis_gist_72.c:413: warning: data definition has no type or storage
> class
> postgis_gist_72.c:415: parse error before `if'
> postgis_gist_72.c:424: warning: type defaults to `int' in declaration of
> `pfree'
> postgis_gist_72.c:424: warning: parameter names (without types) in
> function declaration
> postgis_gist_72.c:424: conflicting types for `pfree'
> ../../src/include/utils/palloc.h:52: previous declaration of `pfree'
> postgis_gist_72.c:424: warning: data definition has no type or storage
> class
> postgis_gist_72.c:425: warning: type defaults to `int' in declaration of
> `pfree'
> postgis_gist_72.c:425: warning: parameter names (without types) in
> postgis_gist_72.c:425: warning: data definition has no type or storage
> class
> postgis_gist_72.c:426: warning: type defaults to `int' in declaration of
> `pfree'
> postgis_gist_72.c:426: warning: parameter names (without types) in
> postgis_gist_72.c:426: warning: data definition has no type or storage
> class
> postgis_gist_72.c:428: parse error before `->'
> postgis_gist_72.c:438: warning: type defaults to `int' in declaration of
> `pfree'
> postgis_gist_72.c:438: warning: parameter names (without types) in
> postgis_gist_72.c:438: warning: data definition has no type or storage
> class
> postgis_gist_72.c:439: warning: type defaults to `int' in declaration of
> `pfree'
> postgis_gist_72.c:439: warning: parameter names (without types) in
> postgis_gist_72.c:439: warning: data definition has no type or storage
> class
> postgis_gist_72.c:440: warning: type defaults to `int' in declaration of
> `pfree'
> postgis_gist_72.c:440: warning: parameter names (without types) in
> postgis_gist_72.c:440: warning: data definition has no type or storage
> class
> postgis_gist_72.c:442: parse error before `->'
> postgis_gist_72.c:482: warning: `gbox_leaf_consistent' defined but not
> used
> gmake: *** [postgis_gist_72.o] Error 1
> postgis-users mailing list
