[postgis-users] polygon creation
Cedric BERNIER
cedric.bernier at thales-is.com
Mon May 13 07:17:40 PDT 2002
Hi all,
I need to create polygons made up circular arcs, is it possible to do this with postgis just like with
ORACLE spatial ?
Jonathan Lowe a écrit :
> Chris,
> You were right. Updating to the proper version of the library file solved
> the problem.
> Thanks very much,
> Jonathan
> Is it possible that it is using an old library file, from when you perhaps
> had postgres
> 7.1 installed in the same directory? I would suggest this as a possibility
> because the
> ggeometry_consistent function is the first function defined in postgis.sql
> which changed
> in the library from 7.1 to 7.2. Check the date on the library file, and
> ensure that it is
> being copied correctly, and referenced correctly by the sql file.
> We have tested it on Solaris 6 on our SPARC box, and it compiles,
> installs, and functions
> correctly, so it doesn't seem to be just a "Solaris bug".
> Chris
> Jonathan Lowe
> To: postgis-users at postgis.refractions.net
> 05/08/2002 04:09 cc:
> PM From: Jonathan Lowe/Oakland/IBM at IBMUS
> Subject: Error running postgis.sql and libpostgis.so.0.7
> Hello,
> An error is surfacing at the tail end of a PostGIS installation on a
> Solaris 2.7 platform with PostgreSQL 7.2.1 and postgis 0.7.0.
> The following commands were successful:
> "make" (with the 72 switch set to "1")
> "make install" (with a perl script fix of some DOS carriage return
> problems)
> "createlang plpgsql <yourdatabase>"
> However, the command "psql -f postgis.sql -d <yourdatabase>" results in the
> following error:
> (...long list of various successful transactions...)
> BEGIN
> psql:postgis.sql:764: ERROR: Can't find function ggeometry_consistent in
> file /local3/pgsql/lib/contrib/libpostgis.so.0.7
> BEGIN TRANSACTION;
> (...remaining function creation statements within this BEGIN work block
> aborted...)
> The path (/local3/pgsql/lib/contrib) and library file are correct and
> exist.
> The statement in the postgis.sql file raising the error is the following:
> -------- 7.2 GiST support functions
> create function ggeometry_consistent(opaque,GEOMETRY,int4) returns bool
> as '/local3/pgsql/lib/contrib/libpostgis.so.0.7' language 'C';
> Commenting out these lines and running the postgis.sql file again results
> in a similar error for the next "create function" statement, which also
> relies on the libpostgis.so.0.7 file.
> Other archived discussions refer to this lib file, but not in the context
> of running postgis.sql.
> Any suggestions?
> Regards,
> Jonathan W. Lowe (jonathan at us.ibm.com)
> Senior IT Specialist, IBM Data Management
> postgis-users mailing list
Type: text/x-vcard
Desc: Carte pour Cedric BERNIER
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20020513/930261f4/attachment.vcf>
