[postgis-users] Error creating GIST indexes in Cygwin 7.2.1
Paul Ramsey pramsey at refractions.net
Tue May 14 10:08:03 PDT 2002
It is in the RTree-over-GiST code, which is used in PostGIS and in
contrib/rtree also. The patch will be against PostGIS (and also
contrib/rtree eventually).
Andy Turk wrote:
> Will the patch be against the 7.2 codebase or Postgis? I'm also wondering if
> they've narrowed it down to a problem in the GiST code or something
> specifically to do with Postgis?
> Andy
> andy at streetlight dot com
> On Tuesday 14 May 2002 08:12 am, you wrote:
> > This (from the error messages at least) looks like the same bug that
> > andyturk at searchlight.com uncovered shortly after release of 0.7. It
> > comes from the new indexing algorithms in 7.2. We have a patch in our
> > hands from the index implementors (GiST authors Oleg and Teodor) right
> > now which might fix it. Should be applied before lunch. So do not be too
> > quick to blame cygwin.
> > P.
> postgis-users mailing list
