[postgis-users] 0.7.0 make install error (cygwin)
Felipe Nievinski
fnievinski2 at terra.com.br
Tue May 14 14:52:39 PDT 2002
Hi.
Norman Vine wrote:
>Norman Vine wrote:
>>Paul Ramsey writes:
>>>If any cygwin experts know what is wrong with my install target,
>>In the meantime the standard install script trips up on
>>the '.exe' extension. Probably easiest for Cygwin users
>>to just manually indicate this in their local Makefiles
>Hi all
>attached find the Makefile I used to create a set of Cygwin PostGIS
>executables
>I don't think that this should break non-Cygwin builds
I've tested it with cygwin v1.3.10-1 and it works fine.
If it works fine in the other environments too (solaris, gnu/linux),
could it be include in the official sources? I find it valuable.
Attached the diff file (from Norman's patch without the DOS carriage
returns).
Regards,
FN.
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20020514/cde0a516/attachment.obj>
