Paul Ramsey wrote: > > Check some queries, do some bounding box queries using 'explain' and see > if you are getting index scans. Remember to 'vacuum analyze' your > database after building the indexes. Be peaceful and good. Dont forget to put an index on the OID of the table you're using. create index oid_geo_idx on <table> (OID); dave
