[postgis-users] Quoting column names in MapServer PostGIS Support
Adrian Custer
acuster at nature.berkeley.edu
Thu May 16 12:23:24 PDT 2002
On Thu, 2002-05-16 at 07:35, Timothy H. Keitt wrote:
> It depends somewhat on whether you will only every access the database
> via the name substitution interface, or whether you might also query the
> from another program. I implemented a postgresql interface in R and
> initially did some name translation (R traditionally uses "." as a
> separator and I substituted them with "_").
I presume you understand that the underscore is an operator?
a_c(1,2,3,4)
is the same as
a <- c(1,2,3,4)
so that substitution might be a tad dangerous.
-adrian
