[postgis-users] sql/function which returns points within certain distance?
Twan Kogels twan at twansoft.com
Wed May 22 04:58:35 PDT 2002
Hello,
I have put a point layer (.shp) with many points in a postgresql database,
i've done this with the shp2pgsql tool supplied with the postgis distribution.
When i let Mapserver load the layer with a postgis connection, all points
appear correct.
I'm now reading the postgis/sql functions of postgis and i'm wondering if
it is possible to create a query which returns all points within a distance
of 10 km. from a center point.
To illustrate my question i have made a picture:
http://www.gdeesha.com/bin/center.gif
As you can see the picture contains several black points, the blue point is
the center point. The red circle is the 10 km circle. Is it possible that a
sql query will return only the black point in the red circle?
(The circle may also be replaced by a rectangle)
Best regards,
Twan Kogels
