[postgis-users] gpc lost database connection - how to debug?
Robert W. Burgholzer
rburghol at vt.edu
Wed May 22 16:34:48 PDT 2002
OK,
Now I've got some polygons (thanks to Paul Ramsey),. but when I execute
any of teh gpc functions I lose my connection to the database. i am
doing these from the command line, using commands such as the folowing:
gistest=# select intersection((select the_geom from microhup where gid
=1),(select the_geom from microsoil where gid = 5) );
server closed the connection unexpectedly
This probably means the server terminated abnormally
before or while processing the request.
The connection to the server was lost. Attempting reset: Failed.
I realize this is experimental code, but I am having a hard time getting
debug info, since I managed to compile without the --enable-syslog or
any other debuggin functions. Are there any other ways of determining
what is happening during these episodes?
Thanks again,
rob
