[postgis-users] Postgis too slow
Paul Ramsey
pramsey at refractions.net
Thu May 23 08:11:12 PDT 2002
Note that the problem I describe is *not* with itemquery or itemnquery.
It is with Stefanos particular use of the FILTER parameter to try and
make a layer which *acts* as if it is doing an itemquery. He is not
using the layer in itemquery mode, he is using it in normal browse mode
and pushing parameters in which would (on a smaller dataset) cleanly
subset the layer using the parameters. It is a cute trick, but it does
not scale at all, because in the presence of the spatial query
associated with browse mode, the attribute query becomes a sequence scan
over all 800000 of his records.
"Obe, Regina DND\\MIS" wrote:
> I find all this pretty fascinating and so far educational. I didn't realize
> how the mapserver and postgis integration works. I have a similar query
> setup using CGI and the speed is pretty decent (under a second local) (but
> the table I use generally for street segment only has 40,000 street segments
> and my memory and processor are a bit better than Stefano's.
> One thing I was wondering about - and whether anyone has tried this.
> Stefano says he has a 600 Mhz processor with 192mb of ram and an 800,000
> record set. I'm wondering if anyone has actually tried doing what he is
> doing using 192mb of memory with that many records. I told him I can barely
> get my server to work with all the services it has to run for that little
> amount of on-board memory. All my servers have at least 256MB ram - even
> the really stupid ones that do nothing.
> The other curiosity I had is that if you set the Layer type to QUERY instead
> of LINE does it still incur the same spatial query penalty - or would
> mapserver-postgis be smart enough to say ("I'm not going to render this so
> just need the extent") and further if the map mode was set to itemquery
> instead of itemnquery - if that minimizes on spatial query penalty since it
> knows to only grab first result.
> -----Original Message-----
> From: Paul Ramsey [mailto:pramsey at refractions.net]
> Sent: Wednesday, May 22, 2002 7:09 PM
> To: postgis-users at postgis.refractions.net
> Subject: Re: [postgis-users] Postgis too slow
> OK, I am now pretty sure the problem was (2) in my previous email. Your
> mapfile layer definition is below. What you are doing is emulating an
> item query by using the FILTER parameter. This is *bad*. It will *not*
> work, because the spatial parameter is way too big, and your attribute
> indexes will never ever get used. The pgsql query optimizer just does
> not know how to handle this combination of spatial and attribute
> indexes.
> To verify that this is the problem, either (1) change your EXTENT so
> that it is a very *small* box which contains just your one test road and
> very little else. Now see how fast it runs. Or (2) remove the FILTER
> entirely (don't to 1=2, *remove* it) and zoom into a small area. Now pan
> around the dataset. That should demonstrate the native spatial query
> speed.
> You are not going to be able to do this query with the standard CGI
> interface. You are going to have to use PHP MapScript and use PHP direct
> connection to pgsql to do the attribute query and find the extent of the
> resultant lines, then set the extent of your map appropriately, then
> render. If you have simple queries, you can use the itemquery in the CGI
> interface, but your query is too complex for that.
> This is map postgis layer:
> LAYER
> STATUS OFF
> NAME "stradeQ"
> CONNECTIONTYPE postgis
> CONNECTION "user=postgres password=postgres dbname=market host=server
> port=5432"
> DATA "the_geom from streets"
> TYPE LINE
> FILTER "(upper(st_nm_base) Like upper('%street%')) AND (l_area_id Like
> '%value%')
> AND ('%number%'='' or '%number%' between l_refaddr and l_nrefaddr or
> '%number%'
> between r_refaddr and r_nrefaddr) "
> CLASS
> SYMBOL 0
> OUTLINECOLOR 25 25 0
> END
> TEMPLATE market.html
> END
> __
> | Paul Ramsey
> | Refractions Research
> | Email: pramsey at refractions.net
> | Phone: (250) 885-0632
> \_
> postgis-users mailing list
