Trying to make PostGIS 0.7.1 as root under Redhat Linux 7.2 with Postgresql 7.2 (USE_PG72=1) and Proj4 (USE_PROJ=1) and getting the following error: ___________ make: *** No rule to make target `postgis_transform.o', needed by `libpostgis.a'. Stop. ___________ Tips? Thanks, Nedjo Rogers nedjo at miningwatch.org
