[postgis-users] Re: make error
Robert W. Burgholzer rburghol at vt.edu
Thu May 30 19:46:18 PDT 2002
I think your problem may be here:
ifeq ($(USE_PG72),1)
You must have the USE_PG72 = 1 if you are using postgres 7.2 or later,
or set = 0 if not. this is in the first several lines of the Makefile.
Hope this helps,
Robert Burgholzer
