[postgis-users] Creating a linestring from two points
David Blasby
dblasby at refractions.net
Mon Nov 4 09:41:41 PST 2002
Per-Olof,
Unfortunately OGC didnt define any constructors for geometries. I should
really add a few functions to do this - perhaps I'll get some time in the
next little while.
If you want to construct a line from 2 points, I suggest you build up a WKT
string:
Lets look at a simple example - a table with 3 geometry columns called
'point1','point2','line'. The point1 and point2 column have points in them.
The function xmin(geometry) returns the xmin of the geometry's bounding
box. For a point, the points X value is the same as the bounding box's X
value. The '||' operator concatenates 2 strings.
UPDATE <table> SET line =
geometryFromText(
'LINESTRING('|| xmin(point1)||' ' || ymin(point1) ||','||
xmin(point2) || ' '|| ymin(point2) || ')'
dave
