[postgis-users] Storage efficiency of point and line data
Paul Ramsey
pramsey at refractions.net
Mon Nov 4 13:31:52 PST 2002
typedef struct
int32 size; // postgres variable-length type requirement
int32 SRID; // spatial reference system id
double offsetX; // for precision grid (future improvement)
double offsetY; // for precision grid (future improvement)
double scale; // for precision grid (future improvement)
int32 type; // this type of geometry
bool is3d; // true if the points are 3d (only for output)
BOX3D bvol; // bounding volume of all the geo objects
int32 nobjs; // how many sub-objects in this object
int32 objType[1]; // type of object
int32 objOffset[1]; // offset (in bytes) into this structure where
// the object is located
char objData[1]; // store for actual objects
} GEOMETRY;
There's the structure, so above and beyond the actual ordinates, we are
storing about 100 bytes of metadata. A bit more fluffy than a shapefile,
but not alot. Admittedly though, when storing single points (or two
point lines), it is a pretty massive overhead.
Michael Graff wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> It seems there is a large overhead to storing point and line data in
> a geometry type. mem_size() returns 172 bytes for a two-point line,
> and goes up by 24 bytes per additional point. Returning the data in
> binary form seems to show only 6 bytes per point, so perhaps this
> is twice the actual storage.
> I thought about storing only the bounding boxes in a table, and
> storing the actual shape in a flat binary file (probably storing
> each lat/long pair as a pair of 32-bit signed integers) but it
> turns out that wouldn't be a huge win, as most of the data I have
> consists of 2 points:
> cnt | points | size
> 23333966 | 2 | 172
> 6789516 | 3 | 196
> 3712433 | 4 | 220
> 2438493 | 5 | 244
> 1749440 | 6 | 268
> 1346119 | 7 | 292
> 976198 | 8 | 316
> 806865 | 9 | 340
> 658199 | 10 | 364
> Is the storage format fairly efficient, and I'm simply storing a whole
> lot of data?
__
| Paul Ramsey
| Refractions Research
| Email: pramsey at refractions.net
| Phone: (250) 885-0632
\_
