[postgis-users] Creating a linestring from two points
David Blasby dblasby at refractions.net
Fri Nov 8 09:19:43 PST 2002
Per-Olof Norén wrote:
> Hi Dave,
> Sorry for the delay. I managed to figure somthing similar out before you
> could answer it.
> Anyway, I used the function x(point1) instead of  xmin though. Isn´t a
> point´s bounding box the point itself?
> or is a point´s bounding box  point+1 unit in every direction? Need
> update using your suggestion?
Yes - your solution is the same as mine (but yours is better).
A point's bounding box is the point itself.
dave
