[postgis-users] strange results
Guido Staub guidostaub at lycos.de
Sat Nov 9 11:18:19 PST 2002
Well,
I've downloaded the cvs snapshot and installed this complete version.
The geometry_columns relation is updated and now have three more
columns, so I think the histogram2d function is now implemented
correctly. But the operators don't work. I still have the same outputs
like I've told before. Does anybody know what I've done wrong? Or do I
have to use a cvs client to get a more actual version of postgis?
Thanks
Guido Staub
chodgson at refractions.net schrieb:
>This error would almost certainly cause your problem, if you have a version
>from before I fixed it. I would suggest you get the latest cvs version and at
>very least undefine (drop) the <</<&/>>/>& operators and redefine (create) them
>using the definitions in the compiled postgis.sql file. Also you have to re-
>create your index. It may be preferable, if possible, to create a whole new
>database using the new postgis (be careful, if you overwrite your old
>libpostgis.so, your old database will be broken) and migrate your data over to
>it - the latest version has Dave's new indexing-prediction histograms in it as
>well
>Chris
>Quoting David Blasby <dblasby at refractions.net>:
>>Guido Staub wrote:
>>>Guido Staub schrieb:
>>>>Hi all,
>>>>I'm using one query but using this one with an GiST-index-scan I get
>>>>no rows back. Using the same query with an seq scan I get one row
>>>>back, as it should be. So, can somebody tell me why I get two
>>>>different results?
>>There was a bug in the "<&" type operators for GiST - chris committed the
>>change to CVS a little while ago.  Perhaps this is whats causing it?
>>dave
>>ps. I've never used the "<<" or "&>" operators, so they havent been well
>>tested
>>_______________________________________________
>>postgis-users mailing list
>>postgis-users at postgis.refractions.net
>>http://postgis.refractions.net/mailman/listinfo/postgis-users
>This mail sent through IMP: http://horde.org/imp/
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20021109/dcada877/attachment.html>
