[postgis-users] compiling error--postgis_transform.c; structure has no member named `is_latlong'
Hector
hector.wong at columbia.edu
Mon Nov 11 15:20:39 PST 2002
Some information--Postgresql 7.2.3 source is used with Postgis-cvs; Red
Hat 8
The error is the following...
postgis_transform.c: In function `pj_transform_nodatum':
postgis_transform.c:54: structure has no member named `is_latlong'
postgis_transform.c:73: structure has no member named `is_latlong'
postgis_transform.c: In function `transform_geom':
postgis_transform.c:251: structure has no member named `is_latlong'
postgis_transform.c:257: warning: implicit declaration of function
`pj_transform'
postgis_transform.c:278: structure has no member named `is_latlong'
postgis_transform.c:293: structure has no member named `is_latlong'
postgis_transform.c:319: structure has no member named `is_latlong'
postgis_transform.c:325: structure has no member named `is_latlong'
postgis_transform.c:353: structure has no member named `is_latlong'
postgis_transform.c:366: structure has no member named `is_latlong'
postgis_transform.c:396: structure has no member named `is_latlong'
make: *** [postgis_transform.o] Error 1
Might anyone know why I might be getting this error? Thanks for any
information you might be able to provide me with.
-hector
