[postgis-users] Postgis layer in mapserver
Jan Hartmann
jhart at frw.uva.nl
Fri Nov 15 07:34:35 PST 2002
It's hard to believe, but
------> using SRID = <srid>
works, but
------> USING SRID = <srid>
or
------> using srid = <srid>
don't, not even in MapServer 3.7!
Dave, couldn't you fix up something for this? I never had this problem,
but that was just pure luck.
Jan
Oscar Testa wrote:
> Ok, but my data express the next:
> DATA "the_geom from (select locarg.oid as oid, locarg.the_geom as
> the_geom, localidad.nombre as nombre from locarg, localidad where
> locarg.codpostal = localidad.codigopostal) AS prueba USING SRID=4326
> USING
> UNIQUE oid"
> and the error is the next:
> MapServer Error in msPOSTGISLayerWhichShapes(): prep_DB:Error executing
> POSTGIS DECLARE statement (0.6 failed - retried 0.5 and it failed too).
> DECLARE mycursor BINARY CURSOR FOR SELECT
> Provincia::text,asbinary(force_collection(force_2d
> (the_geom)),'NDR'),OID::te
> xt from (select locarg.oid as oid, locarg.the_geom as the_geom,
> locarg.codpostal =
> localidad.codigopostal) AS prueba USING SRID=-1 USING UNIQUE oid WHERE
> the_geom &&
> setSRID('BOX3D(-78.22636066 -55.575152,-48.54710934 -20.90357)'::BOX3D,
> find_srid('','locarg,','the_geom') )
> About classes in mapserver, i have no problem. My problem at this
> moment is
> the join....
> Thanks
> Oscar
Jan Hartmann
Department of Geography
University of Amsterdam
jhart at frw.uva.nl
