[postgis-users] Postigs layer in Mapserver
Jan Hartmann
jhart at frw.uva.nl
Fri Nov 15 09:36:00 PST 2002
You are right. The example should run as shown, but it can be made
slightly less complex:
select the_geom from
zipcodes,
(select postal_code, count(*) as total_pop
from data
group by postal_code
) as aggrdata
where zipcodes.postal_code = aggrdata.postal_code
and the MapServer labelitem can be just:
LABELITEM postal_code
Jan
Paul Ramsey wrote:
> You also made a small error in your example of what cannot be included
> in a "GROUP BY" situation. Citing the example
> SELECT COUNT(*) FROM THETABLE GROUP BY POSTAL_CODE
> you said that one could not just include other attributes in the SQL,
> such as POSTAL_CODE, for example. However, POSTAL_CODE is the one
> attribute you *can* include in this situation, since it is the grouping
> variable.
> SELECT POSTAL_CODE,COUNT(*) from THETABLE GROUP BY POSTAL_CODE
> will return the count of postal codes for each distinct postal code. As
> you noted, for any *other* variable, the only way to include them is to
> use an aggregate function, like min() or max().
> Note that you can also include geometries in these statements, but only
> if you use an spatial aggregate function. Currently, there are only two
> spatial aggregates in PostGIS: extent(), and collect(). Extent() returns
> the maximum bounding box of the set of geometries, and collect() returns
> a geometrycollection of the set. Once we have spatial operators like
> union(<geometry>,<geometry>) it might make sense to also create an
> aggregate function union() (although it would be incredibly slow I am
> sure).
> P.
> Jan Hartmann wrote:
>> Sorry, typo again (forgot to install my SQL-checker). The final select
>> should be:
