[postgis-users] Re: [mapserver-users] SDE performance
Jan Hartmann
jhart at frw.uva.nl
Fri Nov 22 03:58:49 PST 2002
(Forwarded. What DO the PostGIS folks think? JH)
Steve Lime wrote:
> Ok, I (call me Steve) will take a look at your proposal. It's sort of
> along the
> lines I was thinking although I was thinking of storing connection
> objects
> themselves and using a connection strings (or portions thereof) as
> keys.
> Any reaction from the PostGIS folks?
> Steve
> Stephen Lime
> Data & Applications Manager
> Minnesota DNR
> 500 Lafayette Road
> St. Paul, MN 55155
> 651-297-2937
>>>>Jan Hartmann <jhart at frw.uva.nl> 11/21/02 07:34AM >>>
> (cross-posted to mapserver-dev)
> Using one database connection for multiple layers could be easier than
> you think with callback functions. Just create TWO arrays: one with the
> CONNECTION strings and one an array of function pointers. All pointers
> are initialized to NULL. With each new CONNECTION, the main program
> copies the CONNECTION string into the CONNECTION array and passes the
> array number to the database subprogram (SDE, PostGIS, Oracle). This
> checks if this connection duplicates a prior one and uses it if it
> finds
> one. Else it opens a new connection. In the case of a new CONNECTION it
> puts the address of a closing function into the second array at the
> same
> position as where it got the CONNECTION string from. In the case of an
> existing CONNECTION it leaves this array element NULL. At the end of
> the
> main program the main application loops through the array of function
> pointers and executes every one that is not NULL.
> There are two benefits to this:
> - The main programmer (let's call him Steve) would have to add only a
> dozen or so lines of pretty trivial code and can put his mind to more
> urgent matters. Everything else, including the closing mechanisms, has
> to be done by the database programmers, which is the way it should be
> - Even more important: database programmers would not be forced to use
> this mechanism. If they want to close each layer themselves, they are
> free to do so, as long as they don't touch the functions array.
> Existing
> code can be used alongside the new mechanism and adapted when the
> individual programmers can find time. The only thing that would have to
> be changed initially would be the manner of passing the CONNECTION to
> the database program: not a string, but a number pointing into the
> CONNECTIONstrings array.
> The following is a working demo:
> #include <stdio.h>
> // CONNECTION string array
> char *connStrings[50];
> // good old-fashioned C: array of funtion pointers returning int and
> // accepting int as parameter
> int (*funcs[50])(int);
> // closing functions, to be defined by database programmers
> int closeSDE(i) {
> printf("SDE closed from connection opened with:
> %s\n",connStrings[i] );
> int closePostGIS(i) {
> printf("PostGIS closed from connection opened with:
> int closeOracle(i) {
> printf("Oracle closed from connection opened with:
> main() {
> int i;
> // initialize arrays
> for (i=0;i<50;i++) {
> connStrings[i] = NULL;
> funcs[i] = NULL;
> // First connection (SDE)
> connStrings[0] = "Connection string for SDE";
> // SDE program opens connection and sets:
> funcs[0] = closeSDE;
> // Second connection (PostGIS)
> connStrings[1] = "Connection string for PostGIS";
> // PostGIS program opens connection and sets:
> funcs[1] = closePostGIS;
> // Third and following connections (all SDE)
> connStrings[2] = "Connection string for SDE";
> connStrings[3] = "Connection string for SDE";
> connStrings[4] = "Connection string for SDE";
> // SDE program uses existing connection and doesn't set closing
> function
> // Sixth connection
> connStrings[5] = "Connection string for Oracle";
> // Oracle program opens connection and sets:
> funcs[5] = closeOracle;
> // Seventh connection
> connStrings[6] = "Connection string for PostGIS";
> // PostGIS program uses existing connection and doesn't set closing
> function
> // main program closes all connections at the end
> if (funcs[i]) (*funcs[i])(i); //obfuscated but working!
> How about it?
> Jan Hartmann
> Department of Geography
> University of Amsterdam
> jhart at frw.uva.nl
> Steve Lime wrote:
>>I think folks will take it seriously, but the timing may a bit bad
> with
>>folks
>>rushing to polish of work in 3.7. At a minimum this should be logged
>>in
>>Bugzilla so it doesn't get lost. If someone would like to work on a
> fix
>>that doesn't involve global variables, but rather a connection pool
>>that
>>becomes part of the main mapObj then I (as the SDE guy) would be
>>happy to work to implement it. I don't think it's too hard, just a
>>bunch
>>of bookeeping since you might leverage multiple SDE/Oracle or
> PostGIS
>>connections in a single run.
>>Steve
>>Stephen Lime
>>Minnesota DNR
>>500 Lafayette Road
>>St. Paul, MN 55155
>>651-297-2937
>>>>>"C F" <gis_consultant at hotmail.com> 11/20/02 12:24PM >>>
>>Regarding MapServer creating a NEW db connection for each db
> layer....
>>is
>>anyone else taking this seriously? I thought this would be just the
>>beginning of the discussion but there doesn't seem to be too much
>>interest
>>in this besides us few. This seems like a pretty unnecessary
>>performance
>>constraint. I would think that it would be a fairly easy fix, but
> it's
>>not
>>my place to be making those assumptions... But I just thought I'd
> bring
>>it
>>up again in case everyone forgot :)
>>>From: Jan Hartmann <jhart at frw.uva.nl>
>>>To: mapserver-users at lists.gis.umn.edu
>>>Subject: Re: [mapserver-users] SDE performance
>>>Date: Wed, 13 Nov 2002 11:57:40 +0100
>>>My impression is that this would not be very hard to implement: just
> a
>>>global array with pointers to every CONNECTION opened in all LAYERS.
>>The
>>>applications itself (PostGIS, SDE, Oracle) could test for already
> open
>>>connections. The only thing MapServer itself would have to do is
>>closing
>>>all connections at the end.
>>>This would certainly be of great help for Oracle and SDE users;
> large
>>>connection overheads have been mentioned regularly on this list.
> Even
>>for
>>>PostGIS there are advantages; think about reusing complex queries
> with
>>>spatial operators and TMP tables. IMHO certainly worth looking into!
>>>Jan Hartmann
>>>Paul Ramsey wrote:
>>>>One possibility would be to abstract the connection making process
> a
>>bit,
>>>>so that a 'getConnection' function first checks a hash to see if
>>there is
>>>>already a connection with parameters which match the requested
>>connection.
>>>>It would probably have to reside on the mapObj though...
>>>>P.
>>>Jan Hartmann
>>_________________________________________________________________
>>Help STOP SPAM with the new MSN 8 and get 2 months FREE*
>>http://join.msn.com/?page=features/junkmail
