[postgis-users] buggy operator && ?
Paul Ramsey
pramsey at refractions.net
Fri Nov 22 09:05:34 PST 2002
Did you include Proj4 support when you compiled PostGIS? If not, then
transform is just an identity operator. (Dave, could we raise an error
instead?)
P.
strk wrote:
> More over: does the transform() function work at all in version 0.7.3 ??
> No matter what srid I give it, the resulting geometry is exactly the same
> as the original one :?
> strk wrote:
>>I need to select geometries overlapping a BOX3D.
>>I don't want to know the SRID of the source geometries,
>>I DO KNOW the SRID of my selection BOX3D.
>>The following selects, though, gives me an error:
>>SELECT * FROM table
>>WHERE
>> transform("the_geom", 32631) &&
>> setSRID('BOX3D(0 0 0, 10 10 0)'::BOX3D, 32631);
>>The error is:
>>ERROR: Operation on two GEOMETRIES with different SRIDs
>>Now, doesn't transform() return a geometry with the specified SRID ?
>>and what about setSRID ?
>>If both these sentences are true, the error is not justified !
>>Note that using
>>GeometryFromText('BOX3D(0 0 0, 10 10 0)', 32631)
>>gives the same result.
>>Any help with this ?
>>I'm using postgis 0.7.3
>>--strk;
>>_______________________________________________
>>postgis-users mailing list
>>postgis-users at postgis.refractions.net
>>http://postgis.refractions.net/mailman/listinfo/postgis-users
__
| Paul Ramsey
| Refractions Research
| Email: pramsey at refractions.net
| Phone: (250) 885-0632
\_
