[postgis-users] finalize PostgreSQL 7.3 support
carl anderson candrsn at mindspring.com
Fri Nov 22 16:44:37 PST 2002
Please note that this stuff is finalizing and has not been fully
santized
for format.  It is fully working though
There area 5 areas that need to be dealt with.  3 in Postgis 1 in
Mapserver
the use of the datatype opaque is strongly deprecated
	use CSTRING or a specific datatype for XXX_in and XXX_out
functions
Casts must be explicitly defined (even the use of the cast in implicit
situations)
     before if a conversion function existed it was used (even
implicitly)
the operator class for GIST needs to be declared using CREATE OPERATOR
CLASS
     the direct manipulation of the pg_amproc table is dangerous and no
long works (pg_catalog)
Add / Drop Geometry Column needs to be schema aware, as would Mapserver
     That's a bigger fish, that I haven't thought clearly about yet.
the Mapserver  mappostgis.c
     Explain now returns multiple tuples as a recordset, not as before
using the NOTICES channel
and lastly I changed to
	DROP TYPE BOX3D cascade;
	DROP TYPE GEOMETRY cascade;
These changes span the *.sql.in files.  I did not presume to rewrite
the build mechanisms
so I hand edited the output file postgis.sql (turning off the
transaction blocks while at it
for testing).
The regression tests are trivial and broken for indexing.  I used a
"real world" mapserver app
to check things out.
Patches against postgis-0.7.3 and mapserver-0.6.3 attached
the postgis-pg0.7.3.patch was created by a diff -u against postgis.sql
(to use the postgis_gist_73.sql file hand edit
'/usr/pgsql/lib/contrib/libpostgis.so.0.7'
and change it to the path of your installed lib.)
I am willing to insert these changes into the regular build path if I
get some direction
on how to mangle the existing *.sql.in files.  The necesary changes
span postgis.sql.in and
postgis_gist.sql.in
Type: text/x-sql
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20021122/e522d089/attachment.bin>
Type: text/x-patch
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20021122/e522d089/attachment-0001.bin>
--- postgis.sql	Fri Nov 22 19:12:56 2002
+++ postgis_gist_73.sql	Fri Nov 22 19:27:41 2002
@@ -212,23 +212,23 @@
-CREATE FUNCTION BOX3D_in(opaque)
+CREATE FUNCTION BOX3D_in(geometry)
    RETURNS BOX3D
    AS '/usr/pgsql/lib/contrib/libpostgis.so.0.7'
    LANGUAGE 'c' with (isstrict);
-CREATE FUNCTION BOX3D_out(opaque)
-   RETURNS opaque
+CREATE FUNCTION BOX3D_out(box3d)
+   RETURNS cstring
-CREATE FUNCTION SPHEROID_in(opaque)
+CREATE FUNCTION SPHEROID_in(cstring)
    RETURNS SPHEROID
    AS '/usr/pgsql/lib/contrib/libpostgis.so.0.7','ellipsoid_in'
    LANGUAGE 'c' with (isstrict,iscachable);
-CREATE FUNCTION SPHEROID_out(opaque)
-   RETURNS opaque
+CREATE FUNCTION SPHEROID_out(spheroid)
+   RETURNS cstring
    AS '/usr/pgsql/lib/contrib/libpostgis.so.0.7','ellipsoid_out'
@@ -246,7 +246,7 @@
 	output = BOX3D_out
-create function WKB_in(opaque)
+create function WKB_in(cstring)
 	RETURNS WKB
    AS '/usr/pgsql/lib/contrib/libpostgis.so.0.7','WKB_in'
@@ -254,8 +254,8 @@
-create function WKB_out(opaque)
-	RETURNS opaque
+create function WKB_out(WKB)
+	RETURNS cstring
    AS '/usr/pgsql/lib/contrib/libpostgis.so.0.7','WKB_out'
@@ -267,13 +267,13 @@
 	storage= extended
-create function CHIP_in(opaque)
+create function CHIP_in(cstring)
 	RETURNS CHIP
    AS '/usr/pgsql/lib/contrib/libpostgis.so.0.7','CHIP_in'
-create function CHIP_out(opaque)
-	RETURNS opaque
+create function CHIP_out(CHIP)
+	RETURNS cstring
    AS '/usr/pgsql/lib/contrib/libpostgis.so.0.7','CHIP_out'
@@ -332,13 +332,13 @@
    AS '/usr/pgsql/lib/contrib/libpostgis.so.0.7','setfactor_chip'
-create function geometry_in(opaque)
+create function geometry_in(cstring)
 	RETURNS GEOMETRY
-create function geometry_out(opaque)
-	RETURNS opaque
+create function geometry_out(GEOMETRY)
+	RETURNS cstring
@@ -386,11 +386,13 @@
    RETURNS BOX3D
    AS '/usr/pgsql/lib/contrib/libpostgis.so.0.7','get_bbox_of_geometry'
 	     LANGUAGE 'c' WITH (iscachable,isstrict);
+CREATE CAST (GEOMETRY as BOX3D) with FUNCTION box3d(GEOMETRY) AS IMPLICIT;
 CREATE FUNCTION geometry(BOX3D)
    RETURNS GEOMETRY
    AS '/usr/pgsql/lib/contrib/libpostgis.so.0.7','get_geometry_of_bbox'
+CREATE CAST (BOX3D as GEOMETRY) with FUNCTION geometry(box3d) AS IMPLICIT;
 CREATE FUNCTION geometry(text)
    RETURNS GEOMETRY
@@ -416,8 +418,8 @@
    AS '/usr/pgsql/lib/contrib/libpostgis.so.0.7','asbinary_specify'
-CREATE FUNCTION bytea(WKB)
-   RETURNS bytea
+CREATE FUNCTION bytea(WKB)
+   RETURNS bytea
    AS '/usr/pgsql/lib/contrib/libpostgis.so.0.7','WKBtoBYTEA'
 ---- Debug (info) functions
@@ -765,40 +767,40 @@
 end TRANSACTION;
-BEGIN TRANSACTION;
+--BEGIN TRANSACTION;
--------- 7.2 GiST support functions
-create function ggeometry_consistent(opaque,GEOMETRY,int4) returns bool
+-------- 7.3 GiST support functions
+create function ggeometry_consistent(internal,GEOMETRY,int4) returns bool
 as '/usr/pgsql/lib/contrib/libpostgis.so.0.7'   language 'C';
-create function ggeometry_compress(opaque) returns opaque
+create function ggeometry_compress(internal) returns internal
-create function gbox_penalty(opaque,opaque,opaque) returns opaque
+create function gbox_penalty(internal,internal,internal) returns internal
-create function gbox_picksplit(opaque, opaque) returns opaque
+create function gbox_picksplit(internal, internal) returns internal
-create function gbox_union(bytea, opaque) returns opaque
+create function gbox_union(bytea, internal) returns internal
-create function gbox_same(box, box, opaque) returns opaque
+create function gbox_same(internal, internal, internal) returns internal
-create function rtree_decompress(opaque) returns opaque
+create function rtree_decompress(internal) returns internal
-create function postgis_gist_sel (opaque, oid,  opaque, int4)  returns float8
+create function postgis_gist_sel (internal, oid,  internal, int4)  returns float8
------- 7.2 RTREE support functions
+------ 7.3 RTREE support functions
 create function geometry_union(GEOMETRY,GEOMETRY) returns GEOMETRY
 create function geometry_inter(GEOMETRY,GEOMETRY) returns GEOMETRY
-create function geometry_size(GEOMETRY,opaque) returns float4
+create function geometry_size(GEOMETRY,internal) returns float4
 ---------Create actual operators
@@ -873,156 +875,26 @@
+CREATE OPERATOR CLASS gist_geometry_ops
+    DEFAULT FOR TYPE geometry USING gist AS
+	OPERATOR 	1	<< , -- poly left
+	OPERATOR 	2	&< , -- poly overleft
+	OPERATOR 	3	&& (GEOMETRY,GEOMETRY), -- poly overlap
+	OPERATOR 	4	&> , -- poly overright
+	OPERATOR 	5	>> , -- poly right
+	OPERATOR 	6	~= , -- poly same
+	OPERATOR 	7	~ , -- poly contains
+	OPERATOR 	8	@ , -- poly contained
+	FUNCTION 	1	ggeometry_consistent (internal, geometry, int4),
+	FUNCTION 	2	gbox_union (bytea, internal),
+	FUNCTION 	3	ggeometry_compress (internal),
+	FUNCTION 	4	rtree_decompress (internal),
+	FUNCTION 	5	gbox_penalty (internal, internal, internal),
+	FUNCTION 	6	gbox_picksplit (internal, internal),
+	FUNCTION 	7	gbox_same (internal, internal, internal),
+	STORAGE 		box;
---- old way = insert into pg_opclass values ('gist_geometry_ops');
-INSERT INTO pg_opclass (opcamid, opcname, opcintype, opcdefault, opckeytype)
-    VALUES (
-        (SELECT oid FROM pg_am WHERE amname = 'gist'),
-        'gist_geometry_ops',
-        (SELECT oid FROM pg_type WHERE typname = 'geometry'),
-        true,
-        (SELECT oid FROM pg_type WHERE typname = 'box'));
---- drop table rt_ops_tmp;
-SELECT o.oid AS opoid, o.oprname
-INTO TABLE rt_ops_tmp
-FROM pg_operator o, pg_type t
-WHERE o.oprleft = t.oid
-   and t.typname = 'geometry';
--- poly_left
-INSERT INTO pg_amop (amopclaid, amopstrategy, amopreqcheck, amopopr)
-   SELECT opcl.oid, 1, true, c.opoid
-   FROM pg_opclass opcl, rt_ops_tmp c
-   WHERE
-      opcamid = (SELECT oid FROM pg_am WHERE amname = 'gist')
-      and opcname = 'gist_geometry_ops'
-      and c.oprname = '<<';
--- poly_overleft
-   SELECT opcl.oid, 2, true, c.opoid
-   WHERE
-      and c.oprname = '&<';
--- poly_overlap
-   SELECT opcl.oid, 3, true, c.opoid
-   WHERE
-      and c.oprname = '&&';
--- poly_overright
-   SELECT opcl.oid, 4, true, c.opoid
-   WHERE
-      and c.oprname = '&>';
--- poly_right
-   SELECT opcl.oid, 5, true, c.opoid
-   WHERE
-      and c.oprname = '>>';
--- poly_same
-   SELECT opcl.oid, 6, true, c.opoid
-   WHERE
-      and c.oprname = '~=';
--- poly_contains
-   SELECT opcl.oid, 7, true, c.opoid
-   WHERE
-      and c.oprname = '~';
--- poly_contained
-   SELECT opcl.oid, 8, true, c.opoid
-   WHERE
-      and c.oprname = '@';
-DROP table rt_ops_tmp;
--- add the entries to amproc for the support methods
--- note the amprocnum numbers associated with each are specific!
-INSERT INTO pg_amproc (amopclaid, amprocnum, amproc)
-   SELECT opcl.oid, 1, pro.oid
-   FROM pg_opclass opcl, pg_proc pro
-   WHERE
-      and proname = 'ggeometry_consistent';
-   SELECT opcl.oid, 2, pro.oid
-   WHERE
-      and proname = 'gbox_union';
-   SELECT opcl.oid, 3, pro.oid
-   WHERE
-      and proname = 'ggeometry_compress';
-   SELECT opcl.oid, 4, pro.oid
-   WHERE
-      and proname = 'rtree_decompress';
-   SELECT opcl.oid, 5, pro.oid
-   WHERE
-      and proname = 'gbox_penalty';
-   SELECT opcl.oid, 6, pro.oid
-   WHERE
-      and proname = 'gbox_picksplit';
-   SELECT opcl.oid, 7, pro.oid
-   WHERE
-      and proname = 'gbox_same';
 END TRANSACTION;
