[postgis-users] RE: [GRASSLIST:5069] RE: Grass to Postgres
Juanse georef at tie.cl
Mon Nov 25 18:00:35 PST 2002
Right, it is actually not that simple to read a postgresql/postgis layer from grass5.1
after reading and trying, trying and reading, it seem that postgis file structure is not suited for grass5.1 postgrass directly reading.
In fmrt files i am ask to provide several fields for grass to be able to find the geometry and category data.
Postgis stores in one column in my case wkb_geometry, a string identifying at the same type the SRID, the geometry type and the actual geometry in wkb, with a constrain at the end that tell pgsql how this string is constructed (Am i right?).
Has anyone build a protocol or sql sentence to prepare a postgis table for the grass requiered format: ie separate geometry from category with the same ID on both tables, and in the geometry table separate the geometry from the geometry type?
which geometry type are allowed in Grass, i have an int4 from >0 to < 5, which are those? which int is equivalente to point, which to line, which to polyline, which to area and so on?
Juanse
temuko-Chile
  ----- Original Message -----
  To: Richard Greenwood
  Cc: postgis-users at postgis.refractions.net ; GRASSList at baylor.edu
  Sent: Monday, November 25, 2002 9:04 PM
  Subject: [GRASSLIST:5069] RE: Grass to Postgres
  I have pass the first wall. I need some Grass help.
  what is the meaning of Location, mapset and database.
  I sort get that they are related to the actual path where the data is? Am i correct?
  I have made the following dir structure
  Inside Home i have created Mapa dir, and inside it a vector dir and inside it a rio dir
  /home
  /home/mapa
  /home/mapa/vector
  /home/mapa/vector/rio
  inside rio i have make two files:
   head (with nothing in it)
  and frmt with
  FORMAT:postgis
  HOST:192.168.0.1
  PORT:5432
  DATABASE:ejercicio
  USER:postgres
  PASSWORD:xxxx
  GEOM_TABLE:rios
  CAT_TABLE:rios
  #GEOM_ID:
  #GEOM_TYPE:
  #GEOM_GEOM:
  #CAT_ID:
  #CAT_FIELD:
  #CAT_CAT:
  rios is a NTAM table in ejercicio. I am using it again for categories. Is that all right or i have to separate geometry from categories in pgsql/gis?
  after running grass51 i have set
  Mapset:     rio
  database: /home/mapa/
  <esc><enter>
  welcome to grass 5.1
  bla bla bla
  GRASS:/home/map/vector/rio> d.mon start=x0
  d.mon: error while lodaing shared libraries: libpd.so: cannot open shared object file: No such file or directory.
  where do i have the mistake?
  Do I need that pqsql library installed in the client machine? why?
  Is is already installed on the pgsql server.
  Do i need to make this path structure by hand for each layer i want to use in grass eventhough they are all stored in the same pgsql/GIS database?
  Juanse
  temuko-Chile
    To: Juanse
    Sent: Monday, November 25, 2002 8:16 PM
    Subject: Re: Grass to Postgres
    It is no bother at all, but I'm afraid that I have not tried connecting to PostGIS from GRASS. I have only used PostGIS with MapServer. Keep trying on the GRASS list and maybe try asking the Refractions guys for help. And please post your finding because I would like to give it a try if I ever find some time.
    Best regards,
    Rich
    At 08:09 PM 11/25/2002 -0300, you wrote:
      Hi Richard
      Sorry to bother directly but seem that this Grass to Postgres is to much for a new comer.
      have you tried it yet?
      can i bother with some questions?
      Having the data already in postgreSQL/PostGIS, how to read it with Grass?
      I am making the head and frmt, but have question as to the definition of various entries, the same applies for location, mapset and database.
      Juanse
      temuko-Chile
      Outgoing mail is certified Virus Free.
      Checked by AVG anti-virus system (http://www.grisoft.com).
      Version: 6.0.417 / Virus Database: 233 - Release Date: 08/11/02
    Richard W. Greenwood, PLS
    Greenwood Mapping, Inc.
    Rich at GreenwoodMap.com
    (307) 733-0203
    http://www.GreenwoodMap.com
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20021125/97241a1d/attachment.html>
