[postgis-users] Another Question on PostGIS Performance
david blasby
dblasby at refractions.net
Tue Oct 1 11:22:27 PDT 2002
I'm not sure if I'm correct here, but I think your performance problem is
based on a "loose" join between veg and veg_atr (pg is not unique).
Here's an example of what I mean. Lets suppose you delete all but one row
from veg (so you only have 1 polygon).
when you do a query like:
select veg.the_geom from veg, veg_atr where veg.pg = veg_atr.pg
You'll get about 160 rows (6591 rows / 40 unique pg values)!!!
Here's a more specific example:
dblasby=# select * from t;
name | pg
dave | 1
(1 row)
dblasby=# select * from u;
pg | data
1 | 1
1 | 2
1 | 3
1 | 4
2 | 1
2 | 2
2 | 3
2 | 4
(8 rows)
dblasby=# select name from t,u where t.pg= u.pg;
name
dave
dave
dave
dave
(4 rows)
So, it looks like you're drawing every feature 160 times (thats 72'000'000
points) - no wonder its slow!
Usually you join tables on a unique attribute - in your case you would
connect a unique column in veg (ie. gid) to another table that relates
gid->hs_zoller (or whatever attribute you're interested in).
Hope this help you look in the right direction. The type of query you're
doing shouldnt take much more than a few seconds (depending on how many rows
you have in your geometry [veg] table).
dave
ps. I was asking how many rows were in your geometry table - but to get the
number of points you can
SELECT sum(npoints(the_geom)) FROM veg;
