[postgis-users] Another Question on PostGIS Performance
Graeme Leeming
gleeming at refractions.net
Wed Oct 2 15:33:59 PDT 2002
Thomas,
Based on the table info you have provided, it appears that you have *not*
created an index on pg in the veg table. You'll need to add a third index
to it of the form "CREATE INDEX veg_pg_index ON veg ( pg );" as done to the
veg_atr table. After another VACUUM ANALYZE see if that makes any
difference...
- Graeme
Thomas Haechler wrote:
> Hi Dave,
> Thanks for your answer. But I think there is a missunderstanding. The pg
> column of the 2nd table is unique and there is an index on it (sorry
> it's called "pg", not my choice). This is how the tables look like:
> Table "veg"
> gid | the_geom | pg | ... |
> 0| ... | 12 | ... |
> 1| ... | 9 | ... |
> 2| ... | 40 | ... |
> 6590| ... | 33 | ... |
> Indexes: veg_gid_index,
> veg_gist_index
> Check constraints: "$1" (srid(the_geom) = 4149)
> "$2" ((geometrytype(the_geom) = 'MULTIPOLYGON'::text)
> OR (NULL::geometry = the_geom))
> --> CREATE INDEX veg_gist_index ON veg USING GIST ( the_geom
> GIST_GEOMETRY_OPS );
> --> CREATE INDEX veg_gid_index ON veg ( gid );
> Table "veg_atr"
> pg | hs_zoller | ... |
> 1| descr1 | ... |
> 2| descr6 | ... |
> 3| descr4 | ... |
> ...| descr.. | ... |
> 40| descr6 | ... |
> Indexes: veg_atr_pg_index
> --> CREATE INDEX veg_atr_pg_index ON veg_atr ( pg );
> And the query string was:
> DATA "the_geom from ( select map.the_geom, data.hs_zoller, map.gid from
> veg as map, veg_atr as data where map.pg = data.pg ) as foo using unique
> gid"
> Maybe the problem is the number of vertices like Paul said, since the
> sum of points is in fact 432574. If I add another condition like:
> veg as map, veg_atr as data where map.pg = data.pg and data.pg<20) as
> foo using unique gid",
> the rendering time is about 9 secs and the sum of points is only 175772.
> Regards,
> Thomas
> THOMAS HAECHLER
> Geographic Information Systems Division
> Institute of Geography
> University of Zurich
> Switzerland
> thomas.haechler at geo.unizh.ch
> postgis-users mailing list
